Page 2 of 2
Re: 1982 R100RS - Hit Pothole, Backfired and Died
Posted: Wed Oct 28, 2015 7:01 am
chasbmw wrote:90% of airhead electrical problems are down to poor connections at the starter relay.
Could indeed be. There are two 81-84 RS electrical gremlin threads going. One here and the other on adv.
The adv RS cuts out when the charge light comes on. It's proving a tough one to diagnose.
This thread's RS has spark. Are the sparks blue or orange?
Re-reading posts helps, I see lots of recent electrical upgrades to the bike. That complicates things.
Posted: Fri Oct 30, 2015 12:14 pm
by jtoml
I had a similar experience recently - rough road, bike started miss-firing, running on one cylinder, intermittently on two but hard to tell exactly. One of the plug leads had lost good contact with the cap. The road side fix was cut a half inch off the end of the lead, re-thread into the cap. Good luck.
Posted: Tue Nov 03, 2015 12:34 am
by mtsfestivus
Hey everyone, thanks so much for your input. After testing all components and getting readings that were in spec, I decided to clean all ground and wiring connections directly associated with ignition issues. I cleaned battery grounds, coil grounds and the jumper wire between, and the wires at the ignition switch. After doing all that the bike has run smoother than ever and I have no more tach issues.
I'd been spoiled by having another 30+ year old bike that had been in a garage most of its life. This one has definitely seen some weather and while it looks good, its internals needed some refreshing.
Thanks for the help. I was able to get her out for some fun riding in the Texas hill country this past weekend. My first airhead, and I'm loving it as much as I thought I would. Especially burning up my buddies on their late-model Bonnies.
