SteveD wrote: ↑Wed Jun 15, 2022 11:24 pm
Are silicone gaskets still an available and useful option? They got some net time a while back but I don't read so much about them any more.
I've only tried soft silicone ones once on my bike and they were total crap. Never again.
They bulged out and got flattened on all the contact surfaces making them almost impossible to re-position properly for a second go around.
I change my oil every 5,000km, oil & filter every 10,000km.
This might seem a bit excessive, but I like my oil clean.
Doing it at '
round numbered' intervals eliminates the need to keep a record or log book or to remember when it was last done.
Each time I change the oil, I remove the valve covers to drain out the oil that's in them.
This also allows me to do a quick rocker 'wiggle' test, and slight tappet adjustment if I '
feel ' like it needs it.
I re-use the same gaskets over and over and over.
From my experience NOTHING beats the OE valve cover gaskets for durability in this situation.
I just give them a (very) slight coating of grease; I've never had one leak. No goop or sealer ever.
This makes for clean and easy replacement when necessary (maybe every 80,000 -100,000km or so).
All the aftermarket ones I've tried that
initially seemed to be as good quality as the OE ones tended to distort and lose their shape and/or crack after only one or two re-uses and needed to be replaced quite often.
My bike only has 540,000km now. Time will tell if I'm doing things right as it gets older.
Nobody ever notices my large r90s style exhaust nuts and black cylinders
