Got Me One
Re: Got Me One
grant81rs wrote:Gidday,
Thanks for the info fellas but....
After raising the front master cylinder a little ... do I have to tape the brake lever back tight into position or anything else?
Wouldn't hurt, but doesn't need to be too tightly held on.
grant81rs
Re: Got Me One
Post by grant81rs »
Gidday,
Last night while slowly trolling through the internet for bike parts in Europe, I stumbled on this pair of very nice keihan stainless mufflers, so I had the seller throw into the postage a flasher relay and rear mudflap for the RS all very cheap. :) and postage was not a killer either.
And with my existing header pipes stainless and in excellent condition that now gives me a complete stainless system.
Also I was reading on a bmw facebook page where a bloke just purchased a new set of Keihan mufflers last week in the UK for an RS and they were 365 pounds ($670.00 oz dollars), my three items were under half that with postage.. :)
Cheers, Grant
Gippsland - Australia
1978 R100RS
1981 R100RS
1994 K1100RS
2005 R1150gsa
Mal S7
Re: Got Me One
Post by Mal S7 »
Its always great to track down a bargain. Just how much was the postage?
I fancy a set of Hoskes from Germany, just because I do, its on my one day when I can waste some money list.
grant81rs
Re: Got Me One
Post by grant81rs »
Gidday,
Mal - $70 Oz dollars gets them to my front door :)
Go on bite the bloody bullet and shout yourself a prezzie!!
Cheers, Grant
1978 R100RS
1981 R100RS
1994 K1100RS
2005 R1150gsa
grant81rs
Re: Got Me One
Post by grant81rs »
Gidday,
So today I had a good crack at the new wiring loom and got power to the dash and the stator motor would engage from the button, then SteveD called in around 5.00pm on his way back through from Dinner Plains and we spent a couple of hours sorting out the USA specked loom to get it over to a UK specked loom, its to do with the headlight wiring on/off at ignition, all is now working, all lights, hi/low, indicators, everything, many thanks SteveD, it was a great help!!!
Now to finish this bike off and get the dash panel and fairing all on.. :D
Cheers, Grant
1978 R100RS
1981 R100RS
1994 K1100RS
2005 R1150gsa
Re: Got Me One
I say, well done old chaps.
You're powering along there Grant.
Was Steve showing any signs of excess curve syndrome? It's getting tough up in the mountains now. More and more blacktop accross the Great Dividing Range.
Re: Got Me One
Grant - I had a complete Keihan SS system on my RS.
Fit was excellent, sounded great, and much lighter than the original.
It took on that lovely SS patina with some use.
grant81rs
Re: Got Me One
Post by grant81rs »
Gidday,
Jeff - I must say Steve was looking a little sheepish and pale around the choppers, could of been either the delayed red wine reaction from high altitude excessive consumption or that excess curve syndrome that I have heard so much of lately as bikes decent down from the mountains and gingerly make their way along the freeways towards the big smoke of the metropolis...
Dougie - Yes the keihan mufflers will be a big improvement on the clapped out, internal-less "'no named" pipes I have on there now, they polished up nice but are very bloody loud .. wait and see I guess!!!
Cheers, Grant
1978 R100RS
1981 R100RS
1994 K1100RS
2005 R1150gsa
Re: Got Me One
More likely a curves withdrawal after tootling down the highway slab for two hours!
Grant, for when you re-route the wiring to tidy it up and have the looms in the right place, might I suggest a couple of things.
1. complete one loom at a time.
2. disconnect each wire and write it's position, and maybe routing, down in a notebook.
Pull each loom back out then route it correctly within the forks. Position it where it will stay before reattaching each wire according to your notes.
Handlebar switch looms x 2, ignition switch loom and main loom. If you did that, you'll end up with a tidier and more accessible headlight. You'll also end up with a loom x loom instruction manual that's exact for your headlight and will be a great resource if future fiddling about is required. It'll be infinitely easier than reading the diagram.
It would also be much easier to put new protective covers on the handful of naked connections before repositioning them.
bbelk
Re: Got Me One
Post by bbelk »
Good advice but it is so much easier in these modern times to just take lots and lots of pictures.
1979 R65
