OZ get together this Spring?
Mal S7
Re: OZ get together this Spring?
Post by Mal S7 »
SteveD wrote:Mal, are you still running points?
Nope, Boyer for the last 50 thousand kms. It starts easily and idles OK. I think electronic ignitions either work or fail completely, no?
btw speaking of how much you can pack, to cheer me-self up I got a new compact tent for the trip.
Mal S7 wrote:I think electronic ignitions either work or fail completely, no?
Nope. The two most common failures are the one you describe, and failing or missing when hot and working again when cool. A third kind of failure is much less common, but that would be just weird unpredictable behavior - not nearly as common as the other two.
Mal S7
Post by Mal S7 »
Hmm thanks MS. Is there a way to test an EE unit? I guess at a pinch I could stick the points back in ....
Mal S7 wrote:Hmm thanks MS. Is there a way to test an EE unit? I guess at a pinch I could stick the points back in ....
Yeah, unfortunately, unless it's completely dead, or goes completely dead when hot, the only way I know to "test" it is to replace it with a known good unit and see if it changes the behavior. Replacing with points would pretty much be the same thing.
Mal S7
Post by Mal S7 »
Well it's rolling again. I only rode around for about half an hour but couldn't provoke a miss,
went looking for the steepest hill around here, and if you know central NSW, you know that's more a gentle slope.
Still seems down on power and rough though, despite returning to base to re-balance the carbs.
Sparks are blue, but look a bit weak.
I will order new leads and stuff and see.
Bob Bennett
Post by Bob Bennett »
So Mal what do you think the problem was?
I'm just a bit curious Mate.
Regards Bob.
Regards, Bob
R80 RS
Mal S7
Post by Mal S7 »
Bob Bennett wrote:So Mal what do you think the problem was?
Regards Bob.
Gday Bob,
Not as curious as me! I think it may still be lurking. Waiting for a coil or lead or EE unit to get hot enough.
btw I have shopped around, S Meyer are most expensive for coils, 110 euro, each!
Hi,
item correct for your bike. Price is for one coil. You need 2 of the items for one bike.
Besuchen Sie unseren neuen Online-Shop: www.meyer-bikes.com
Visit our new Online-Shop: www.meyer-bikes.com
Mit freundlichen Grüßen – Best regards
Second hand monolever coil, marked Made in Slovenia. They're the go. 2:1 coil. The earlier ones are called crackomatics for a reason.
A Harley coil will also work...cheap enough. Just need the 1.5 ohms version.
There's always a Brown Dyna 1.5 ohm twin coil USD95 plus post. http://www.motoelekt.com/ignition.htm Excellent coil. I have one and Grant too!
grant81rs
Post by grant81rs »
Gidday Fella,
mal I have two new spare green dyna coils in the cupboard from http://www.motoelekt.com/ignition.htm
I also have tucked away the new Alpha Classic ignition system which I have not installed on the 78RS yet, thats another job to sort out one day.
Not quite sure of the year your bike is but if the specs suit I can post you up a brand new Motoelekt green dyna coil for the cost price as listed if you want, just fix me up at the Blue Duck..
Hope this help you out and cheers
Cheers, Grant
Gippsland - Australia
1978 R100RS
1981 R100RS
1994 K1100RS
2005 R1150gsa
Mal S7
Post by Mal S7 »
Hey Grant, thanks for the offer. I may need it yet. Put an order in on Motobins that jammed at the last hurdle, I shoulda used paypal, who invented friggin' credit card verification steps? Got no order confirmation but I can see it sitting on my Motobins account, and with the time difference they are closed for the night.
Sigh. The bike runs. I will pack a spare makeshift lead and the old points and gear just in case, and when you'se are all asleep I will swap in some decent coils ... shhhhhh
cheers
Mal
