Just wanted to show off my new
Tool junkie...
Re: Tool junkie...
Wow I didn't want to start this all over again - sorry.
Just wanted to show off my newbling tool.
Re: Tool junkie...
OK, I'm not getting into this one.
Buy a load cell that fits between socket and ratchet and/or extension; test, rinse, repeat and report. We don't live in a static World.
1971 R75/5 (SWB)
Re: Tool junkie...
You are fine. My post IS the answer. There is one way to tell how much torque is applied to a fastener by a socket, etc. measure it at the fastener - case closed on that deal. Again not a static World; fasteners are insanely more complex than any equation I was taught by the same engineers that said, "Never use this for data!"
1971 R75/5 (SWB)
Re: Tool junkie...
What happened to "Airheads - Simple by Choice"?dwire wrote:There is one way to tell how much torque is applied to a fastener by a socket, etc. measure it at the fastener - case closed on that deal.
Re: Tool junkie...
Good one...
I'm sure I was "in on this" (topic) before; likely when the blisters were still fresh on my hands from doing torque to seal, and torque to yield on both tube nuts (offset situation) and bleeder valves (not offset) on just about every brake product known to man. Sucked...
Oh yeah, Snap-On makes a digital load-cell "get up" for between a socket and offending extension or your ratchet end; don't recall it being all too prohibitive for the obsessive.
Not sure about your quote and yes the '71 is air-cooled, but I am afraid I am the more likely "Air-Head" of the two!
1971 R75/5 (SWB)
Re: Tool junkie...
IME, there are really only a handful of places where a torque wrench is needed...most other locations are just tightened to a snug level or a feel...one should really develop some kind of "feel" when working on these bikes. I believe the "bling", er, tool in question was to be used on the driveshaft bolts at the back of the tranny. Sufficient torque can be achieved using the tool kit wrench with a rag in the hand and giving it a good grunt...use of blue loctite can help to ensure the bolts stay in place and secure. Getting a load cell into this area is impossible. I believe Sears also sells one of these devices, too.
Re: Tool junkie...
Kurt - I have done it before exactly as you described with success. Like I said - "tool junkie".Kurt in S.A. wrote: I believe the "bling", er, tool in question was to be used on the driveshaft bolts at the back of the tranny. Sufficient torque can be achieved using the tool kit wrench with a rag in the hand and giving it a good grunt...use of blue loctite can help to ensure the bolts stay in place and secure. Kurt in S.A.
Try the purple (Loctite 243), same as the blue (242) but it is oil resistant.
Re: Tool junkie...
Well known "affilication"...BTDTHT (...added the Have That).dougie wrote:Like I said - "tool junkie".
Re: Tool junkie...
I would agree whole heartedly...Kurt in S.A. wrote:IME, there are really only a handful of places where a torque wrench is needed...most other locations are just tightened to a snug level or a feel...one should really develop some kind of "feel" when working on these bikes. I believe the "bling", er, tool in question was to be used on the driveshaft bolts at the back of the tranny. Sufficient torque can be achieved using the tool kit wrench with a rag in the hand and giving it a good grunt...use of blue loctite can help to ensure the bolts stay in place and secure.
Again absolutely true, was it not you that was telling us what engineering says about how the equations in question truly work?Kurt in S.A. wrote: Getting a load cell into this area is impossible. I believe Sears also sells one of these devices, too.
My statement was a direct reflection on that, not the implication that one would ever use a load cell anywhere on a BMW. An accurate load cell would show a person that the calculations work well enough for anything we would likely ever do on our BMW's (just as common sense and one's hand will too in most places) but DO NOT work in practice with accuracy and while math, theory can be sound, it does not necessarily reflect the reality of the World we live. If you used a load cell and compared measurements to the "engineering facts" you would understand this - that was all I was illustrating friend.Kurt in S.A. wrote: ...That's the engineering facts...
1971 R75/5 (SWB)
Re: Tool junkie...
I think we're on the same page... +1.dwire wrote:that was all I was illustrating friend.
