Page 3 of 6
Re: Bendix Gear
Posted: Mon Dec 06, 2010 6:10 am
Garnet wrote:Only half of the ring gear will show wear as the engine usulllay stops in two different spots, about half way up the compresion stroke on one or the other cylinders.
On a point of order...
doesn't make much difference but, in fact, there will normally only be one area of extra wear on a Boxer ring gear. The crank tends to stop at roughly the same place no matter which cylinder is on the compression stroke. This is true of any 2 cylinder engine where the cylinders fire at equal intervals. A 4 cylinder engine will have two areas, a 6 cylinder engine 3 areas and so on.
Re: Bendix Gear
Posted: Mon Dec 06, 2010 1:10 pm
Rob Frankham wrote:Garnet wrote:Only half of the ring gear will show wear as the engine usulllay stops in two different spots, about half way up the compresion stroke on one or the other cylinders.
Well, he was still mostly right: the engine usually stops in
one spot: "about half way up the compression stroke on one or the other cylinders."
Or is that only 1/2 right?
Re: Bendix Gear
Posted: Mon Dec 06, 2010 3:48 pm
by Garnet
Major Softie wrote:Rob Frankham wrote:Garnet wrote:Only half of the ring gear will show wear as the engine usulllay stops in two different spots, about half way up the compresion stroke on one or the other cylinders.
Hey, 1/2 right is close to a 50% improvment for me.
Re: Bendix Gear
Posted: Tue Dec 07, 2010 3:10 am
by Bob Bennett
Good news, she's startin great, any time, any where. Thanks everyone for your help.
Just for the record, wirewrkr was spot on, I didn't realise that there were bushes in the bendix shaft,
if I had it would have been a lot cheeper than buying a whole bendix, in my defence though there is no
sign of any bush or part thereof in the original bendix, the PO was obviously a %$#$#@, you can see all
in the photo.
Thanks again to everyone for your help.
Re: Bendix Gear
Posted: Tue Dec 07, 2010 4:47 am
Bob Bennett wrote:the PO was obviously a %$#$#@...
Hasn't anyone ever told you? The PO is ALWAYS a %$#$#@.
Well, even if only
because of the missing bushing, it was worn enough that replacing the whole thing was wise.
Re: Bendix Gear
Posted: Tue Dec 07, 2010 5:21 am
by Sibbo
So ,it would have been tilting and jamming under load ? Why only when hot ?
Re: Bendix Gear
Posted: Tue Dec 07, 2010 5:40 am
by Bob Bennett
G'day Sibbo, maybe the tube expanded just that bit extra causing more slop, or the grease on the
spline was hard enough when cold to keep it straight enough when cold, I dunno!
The problem started before Guyra and it started OK up there in the morning didn't it?
Re: Bendix Gear
Posted: Tue Dec 07, 2010 5:46 am
by Bob Bennett
Major, Maybe it wouldn't be so worn, and buggered the ring gear, if he had left some bushes in it.
Re: Bendix Gear
Posted: Tue Dec 07, 2010 6:47 am
by Sibbo
Bob Bennett wrote:G'day Sibbo, maybe the tube expanded just that bit extra causing more slop, or the grease on the
Yep perfectly , but it was cool .The hard grease makes sense ,but there can't be much tilt in it .How did it feel when you cleaned it up ?... the old one .
Re: Bendix Gear
Posted: Tue Dec 07, 2010 1:39 pm
Major Softie wrote:
Well, even if only because of the missing bushing, it was worn enough that replacing the whole thing was wise.
Bob Bennett wrote:Major, Maybe it wouldn't be so worn, and buggered the ring gear, if he had left some bushes in it.
Uhm, that was my point. I mean, I put the word "because" in italics and everything.
