Mikunis on an R100RS?
Frog
Re: Mikunis on an R100RS?
Post by Frog »
As you may know, I recently the top end of my slash five rebuilt. It had 114,000 miles on it and was ready for some love.
In looking into the options, I explored some of the possible directions. When I added up the costs of what would be involved, I decided to back off a bit. I ended up going from 750cc to 800cc, since the cost was the same as my needed re-bore and new pistons. I went to a higher compression, as it was not an expensive upgrade (high compression pistons were not more expensive and the head machining was reasonable). I added a lower plug, in case I need to dual plug due to the higher compression. This was also reasonably done, since the heads were in for a rebuild. I opted not to do a 336 cam and switch to mikuni's...due to cost.
Since I know the bike well, I can say that the change is noticeable and welcome. I recently went on a ride two up and enjoyed being able to pass cars without worry.
vanzen
Post by vanzen »
r90s wrote:Make the bike, and yourself, lighter in weight.
It'll make a bigger difference and it will be easier to accomplish.
JEEZUZ, R90s – I'm at a buck & seventy !
That weight has gotta come off the bike, man !
vanzen@rockerboxer.com wrote:JEEZUZ, R90s – I'm at a buck & seventy !
You reckon you got troubles Vanzen, I just flicked my scales from KG's to LB's.
I came up $1.60. !
No wonder those sports bikes can't catch me :mrgreen:
Lemme see, $1.60 might equate to dual plugging, 336 cam, mikuni's :mrgreen: and rocket fuel. All for free!
I need the rocket fuel! :)
You mean I have to give up my ample beer storage? :shock:
Garnet wrote:You mean I have to give up my ample beer storage? :shock:
No, not at all Garnet. Just take up smoking!
It robs me of 10 kg.
vanzen
Post by vanzen »
ME 109 wrote: No, not at all Garnet. Just take up smoking!
10kg ? What will that be in dog years ?
vanzen@rockerboxer.com wrote:10kg ? What will that be in dog years ?
That does get right to the point, doesn't it Vanzen. I should consider others.
What would that be in stones?
Garnet wrote:What would that be in stones?
10 years at least if employed.
6 months if unemployed.
