What's with these #!%^*! stands?
Re: What's with these #!%^*! stands?
SteveD wrote:Yours is different to mine Sunbeem. Mine doesn't incorporate the footpeg.
#91694 for 81-84.
http://www.motobins.co.uk/displayfinal. ... oot&go=GO#
And mine is different as well -
#91695 for '85 on. http://www.motobins.co.uk/bmw-parts.php?model=R Series 2 valve Twin
An interesting link. I see the side stands thru /7 aren't for sale to the rest of the world, probably because the footpeg requires a mod. Anybody have an idea what the mod does? I'm guessing that it has all to do with the fact that the /5 thru /7 footpegs mount onto the thru rear engine mounting bolt. So I'm guessing the mod is to make room for the upper, non swinging, part the Surefoot.
I know that the '85 and up momolever airheads require a longer thru bolt if you want to mount a Brown sidestand. I pulled the longer rear thru bolt from a parts bike that I will use to mount the Brown sidestand onto my '91RT.
I understand that the Brown side stands are becoming increasingly scarce (and increasingly expensive) here in the U.S. A Surefoot side stand would seem to be a viable option especially if the Surefoot stands were available here.
Ken in Oklahoma wrote:I know that the '85 and up momolever airheads require a longer thru bolt if you want to mount a Brown sidestand. I pulled the longer rear thru bolt from a parts bike that I will use to mount the Brown sidestand onto my '91RT.Ken
The Surefoot also requires a longer bolt, but it is supplied with the stand.
