Re: Working on the engine - internal top-end rust
Posted: Mon Aug 15, 2011 6:51 pm
Spark plugs are white-ish.
Boxerworks Member Forum
https://boxerworks.com/forum/
When I had heads rebuilt I learned that new springs were $6.00 each. That was about 6 years ago.Jean wrote:. Soooooooo...if "we" can find some valve springs from an oily junked engine...Rob can use them (? yes?)
Rob, by ANY chance do you still have the OLD engine?
Thanks Jean (and everyone).Jean wrote:If they are whitish after 300 miles, you are not burning oil. Or at least not so you would notice. At this time, baring any other lost or broken parts...the only thing you have to deal with is the oil LEAK from someplace. If you are sure it was the rear drive, carefully clean the loose rust off the parts, oil them and rebuild. If the springs are pitted I''d replace them if possible...depends on the pits. ANY pit is a stress concentration and the spring could break. Ugly for the engine. Spoils the piston.
Anybody out there got any springs? What fits?? = According to the various catalogs I have, the valve springs for the R-bikes in the years of late 70's early 80's are all the same. only some of the small parts are different: the keepers and retainers. Soooooooo...if "we" can find some valve springs from an oily junked engine...Rob can use them (? yes?)
The cat is doing fine, and doing her job fine. She slept on my pillow against the top of my head last night. She NEVER sleeps against me, and never up there.Chuey wrote:F'n-A Rob, Jean asked about your cat. I didn't see where you told her how your cat is. Are you OK?
You may be able to rent one, especially if you live near a decent sized metro area. If so, it will probably be MUCH better quality than buying a cheap one, and probably cost you less.justoneoftheguys wrote: Now I need to find a cheap spring compressor.
