Bleeding Rear Brake on RS driving me crazy!!!!
Re: Bleeding Rear Brake on RS driving me crazy!!!!
Zombie Master wrote: You really need to come to Canada and get yourself some real beer.
Hell yeah!
Hey, is Disneyland still open? Always wanted to go there for real.
buzz
Post by buzz »
I went through the same problem recently.
After lots or pumping & bleeding I ended up doing what has been mentioned here.
- Get the bleed nipple as high as possible
- Wedge the rear brake pedal down and leave over night to let any air bubbles move up to the nipple
- Then bleed the system again.
It worked a treat - best the rear brake has been for ages.
In sympathy with the "Bleeding" theme of the thread - now my ''bleeding'' turn indicator light is not working.
Gary
R100RS
R100GSPD
Darryl Flynn
Post by Darryl Flynn »
buzz wrote:I went through the same problem recently.
BLEEDIN ELL! ( It's a Brit thing ) :D
My other bike is a Guzzi
Re: Bleeding indicator light
Buzz...I think the bleeding turn indicator light problem is the bleedin' turn-indicator relay.
It's also expensive.
Darryl Flynn
Jean wrote:Buzz...I think the bleeding turn indicator light problem is the bleedin' turn-indicator relay.
No, IT's BLEEDIN Expensive :D
Lizzie would say bleedin'
Must spell it correctly. :mrgreen:
German Ebay, full set of s/hand relays $20-25 :idea:
buzz...if it's the indicator on the dash, check the folded copper connection on the circuit board, where it connects to the globe. It might be cracked. A tiny piece of folded aluminium foil can fix bleedin' problem.
buzz
Post by buzz »
SteveD wrote:buzz...if it's the indicator on the dash, check the folded copper connection on the circuit board, where it connects to the globe. It might be cracked. A tiny piece of folded aluminium foil can fix bleedin' problem.
Thanks Steve
Unfortunately, the circuit board is full of bleedin' folded aluminium foil :lol:
Gary
R100RS
R100GSPD
<$20 from Ebay Germany. :mrgreen:
buzz
Post by buzz »
ME 109 wrote:<$20 from Ebay Germany. :
Thanks, but I have my Australian agent on to it - it's easier for me that way & helps him.
Gary
R100RS
R100GSPD
