Page 3 of 4
Re: Bleeding Rear Brake on RS driving me crazy!!!!
Posted: Fri Sep 21, 2012 6:54 am
Zombie Master wrote:
You really need to come to Canada and get yourself some real beer.
Hell yeah!
Hey, is Disneyland still open? Always wanted to go there for real.
Posted: Sat Sep 22, 2012 7:20 am
by buzz
I went through the same problem recently.
After lots or pumping & bleeding I ended up doing what has been mentioned here.
- Get the bleed nipple as high as possible
- Wedge the rear brake pedal down and leave over night to let any air bubbles move up to the nipple
- Then bleed the system again.
It worked a treat - best the rear brake has been for ages.
In sympathy with the "Bleeding" theme of the thread - now my ''bleeding'' turn indicator light is not working.
Posted: Sat Sep 22, 2012 11:46 am
by Darryl Flynn
buzz wrote:I went through the same problem recently.
BLEEDIN ELL! ( It's a Brit thing )
Re: Bleeding indicator light
Posted: Mon Sep 24, 2012 3:50 pm
by Jean
Buzz...I think the bleeding turn indicator light problem is the bleedin' turn-indicator relay.
It's also expensive.
Posted: Mon Sep 24, 2012 4:57 pm
by Darryl Flynn
Jean wrote:Buzz...I think the bleeding turn indicator light problem is the bleedin' turn-indicator relay.
No, IT's BLEEDIN Expensive
Posted: Mon Sep 24, 2012 5:07 pm
Darryl Flynn wrote:Jean wrote:Buzz...I think the bleeding turn indicator light problem is the bleedin' turn-indicator relay.
Lizzie would say bleedin'
Must spell it correctly.
German Ebay, full set of s/hand relays $20-25
Posted: Mon Sep 24, 2012 11:14 pm
buzz...if it's the indicator on the dash, check the folded copper connection on the circuit board, where it connects to the globe. It might be cracked. A tiny piece of folded aluminium foil can fix bleedin' problem.
Posted: Mon Sep 24, 2012 11:51 pm
by buzz
SteveD wrote:buzz...if it's the indicator on the dash, check the folded copper connection on the circuit board, where it connects to the globe. It might be cracked. A tiny piece of folded aluminium foil can fix bleedin' problem.
Thanks Steve
Unfortunately, the circuit board is full of bleedin' folded aluminium foil
Posted: Tue Sep 25, 2012 12:00 am
<$20 from Ebay Germany.
Posted: Tue Sep 25, 2012 1:06 am
by buzz
ME 109 wrote:<$20 from Ebay Germany. :
Thanks, but I have my Australian agent on to it - it's easier for me that way & helps him.
