Gidday Fellas,
So today I got the local on site auto electrician to swing by my house and give my K the once over with his professional testing gizmo's, he checked this and that as I wanted to be pointed in the right direction first and also make sure I was not barking up the wrong tree with my faulty speedo fact finding mission that lay ahead of me over this coming easter..
I have power to both front and rear abs sensors as these were both undone when I collected to bike last week, so thats good to know, he had to use a special tester because of the low pulse to the abs sensor??
I also have power to the rear speedo sensor on the final drive
My trickle charge socket on the left side now works, again a loose wire and also I thought that my 240v charge was playing up last weekend, not to be and all good to go.
All my fuses and dash pad switches are all correct and working fine.
So now I can start with removing the speedo housing and give the connections all a good clean up...
Anyway I am chipping away at it slowly as I have not much good with the electrical side of things but can see myself learning rather quickly with this bike...
Look What I Done
Re: Look What I Done
Cheers, Grant
Gippsland - Australia
1978 R100RS
1981 R100RS
1994 K1100RS
2005 R1150gsa
1978 R100RS
1981 R100RS
1994 K1100RS
2005 R1150gsa
