I'm sorry to say this but that lighter brown color suggests that water has gotten into your transmission oil. Not a good thing, though no damage may have been done. It happened to me on my '77 R100/7, but my gears were apparently OK.Holysmoke wrote:Ordered new floats, spark plugs, fuel line and intake boots. Drained and replaced the tranny oil. It was a lighter brown color
You're wondering how that water got in your oil, I reckon. Aside from pressure washers there is a little suspected point of entry where the speedometer cable goes into the transmission. Despite the fact that there's a rubber boot covering the junction, that boot is often insufficient. The classic problem is rain water or other water getting onto your speedometer cable then wicking it's way down, inside past the rubber boot, and then into the transmission.
Presuming that your transmission is still OK there are two 'classic' remedies. You will need a new rubber boot for both. One remedy is to put a zip tie around the boot at the top to positively squeeze the boot against the cable sheath. The other is to fill the boot with bearing grease or some similar heavy grease to form a 'mechanical' barrier to water wicking it's way into the transmission.
