dwire wrote:Tricky, tricky... Good to use lots of places, but help me out...
I like it and use it elsewhere but, how does it not tell him that the contacts are worn in the solenoid, the ground to the same is no good??? Not sure I get it. The only way that meter reads any DC is with a complete circuit, the only way it gets that is through the solenoid - unless of course I have not had enough coffee yet...
I am quite interested, but at a loss why when you could just measure the cables' resistance and as well when you disconnect it/them, you can not only work the ends around doing so, but also be ready to move on to taking a current measurement of the starter draw if you need to move forward...
Please let me treat two posts in this one post. I don't know how to put quotes from two posts into one post. But, I can copy and paste.
Doug, your suggestion of checking the DC resistance is fraught with possible error. The crappy crimp and corrosion sometimes will chemically make a crude diode. The result is that the cable is no longer a linear conductor. The resistance will change according to the level of current. The low level of voltage in the mulitmeter may show a different number of Ohms compared to the result of using a higher voltage, which means a higher current. Basically, you run a risk of thinking that you have measured something, but didn't get a result that can be trusted.
Your suggestion of measuring the actual current flow is a very good one and assures a more accurate reading. That will allow a better diagnosis. To use a voltmeter to measure the voltage drop over the length of the conductor is just as accurate and easier than disconnecting to get the ammeter in line.
Keep in mind that an ammeter is just a volt meter with a shunt across it. By attempting to measure current, you are only doing the "measure the voltage drop" of the cable. Both conditions, of course, must be done under the exact load of operating conditions. I think that we tend to forget how an ammeter works. Does this make sense?
Depending on the chemistry, the non linear conductor can amount to an old fashioned spark gap transmitter, or a circuit that can absorb different radio signals and mix them in a way to produce a new signal on some frequency. This new signal can be very strong and transmit for many miles. It is known as spurious radiation, or a spur.
You ask, "So what?" in our older bikes we don't care about a few micro watts of stray RF energy. However, as we have now gone to microprocessors that live on very low level signals, we stand a chance to interfere with the computer on board. They may all be protected from stray RF by this date, but I don't know that.
Garnet said, "You stil haven't determined that you actally need new cables. Other than crappy crimp connections, battery cables don't wear."
It is true that battery cables don't wear, but a crappy crimp is not the only devil to find. As air creeps up the insulation of the cable, the moisture does corrode. This chemical process will seriously reduce the cross section of copper. Basically, over time the wire becomes smaller and smaller. That section within the last inch or so becomes the point of higher resistance.
Isn't it fun to pick even deeper and deeper into things? My Aspberger's is showing.
