My pressure plate and pressure ring look ok - at least according to Duane's web page. The Friction Disk was 5mm. The book says replace at 4.5 mm. The parts guy says my diaphram spring needs to be "at least" 19mm. Mine is a nice uniform 16mm.
So - I am shelling out $250 and getting a friction plate and a diaphram spring.
plus driveshaft bolts
There is no endplay (cold) on the transmission. The friction plate did feel "sticky" when sliding it on and off the transmission, but not too bad. The splines look uniform all the way to the back past the point where the disk rubs. The wear on the back of the pressure ring was minimal.
I would really like to have a smooth clutch.
I think even if the new diaphram spring is 3 or 4 mm taller than the old one, that I will still be able to start the bolts. I had no problem at all comming out. Everything was relaxed before I ran out of threads.
Clutch issue
Re: Clutch issue
Your labor is "free" and so it isn't so important for you to get it right the first time, as in a shop. If it is still grabby after this work, then you can remove the transmission and respace the input shaft.
We would never risk this in my shop when the symptom was a grabby clutch.
Re: Clutch issue
So on that happy thought...........Duane Ausherman wrote:Your labor is "free" and so it isn't so important for you to get it right the first time, as in a shop. If it is still grabby after this work, then you can remove the transmission and respace the input shaft.
I am off to a party - then moms - then the coast.
1979 R65
1979 R65
