Re: Slash five tuning help
Posted: Fri Feb 04, 2011 1:32 pm
First off, I want to thank you all for the in depth efforts to help.
Here is what I have to report:
I was lucky enough to catch Duane working in my area, so I roped him into coming over for some diagnostic fun and catching up.
We first started by going over the symptoms of the bike. Duane noted right away that the carburetors were poorly tuned and out of synch. I knew this, as my previous carburetor tuning efforts had had to be aborted due to this ignition issue. Duane did as much carburetor tuning as was possible and managed to make it run a little better.
Please note that the bike does fire right up and idle/run well enough to ride. If you did not know these bikes, you might even think that it is normal.
Then I put the timing light on the bike and showed him how the left skipped, while the right sparked without hiccups. Even at higher rpms (2,000 or so), the pause in the light (spark) is long enough to really notice. We determined that this was equivalent to missing much more than one spark, but instead a whole series.
o The first test that we did was to swap the ignition leads, but keep them on their original coils. We had the left coil running the right side and vice versa. The problem remained on the LEFT.
o The second test that we did was to swap the spark plugs. The problem remained on the LEFT.
At that point, we assumed that we had eliminated ignition/coils as the culprit and decided to put things back in place and move on to swapping the left side carburetor with the one on my bike (which runs great).
But, while under the tank, I decided to install by other spare (used) coil, so that both of my spare coils would be in the bike. I figured that this would not mess up our testing and would possibly teach us something else.
Well, that seems to have fixed the problem. We put the timing light back on and tried both sides. We could not find a miss and the bike seemed to by running properly (minus some needed carburetor tuning).
It was too late for me to go for a ride and until I do so, I don’t want to break out the champagne.
After our testing, I decided to put the bike on the lift and install a grounding wire from the diode ground, to the coil mount and finally to the battery negative. With all of the powder coating on the engine mounts, I figured that this would insure that the systems would be properly grounded. I have not run the bike since, but plan to today.
I know that our conclusions do not really explain all of the symptoms. Did I have bad coils? Did they need to be grounded and my removal and installation of the right one improve its ground?
It seems that the two nicks in the coil mounting brackets, that dig into the coil case, must serve to ground it. Duane also remembers that when he used to set up the ignition system on the bench for demonstrations, they had to run a grounding wire to the outside of the coil. This seems to contradict what is being said here. I did a little coil reading online and it seems that the mounting to a good ground is important.
I do think that the powder coating of the frame compromised the grounding of the frame.
I hope that this does not add to the confusion.
