Page 4 of 6
Re: Main loom.
Posted: Sun Feb 20, 2011 2:01 pm
by grant81rs
Gidday Steve,
Reading and watching with interest here on this one mate, I wish I could offer a little help but electrics twist my mind to much, am finding the problem solving intersting to follow with the posts......
Re: Main loom.
Posted: Sun Feb 20, 2011 3:30 pm
by Airbear
Yep, we're all rootin' for yer, Steve.
Tim's right. You need some more volts. I'd attach some if I could. Hopefully the battery will be better charged this morning, otherwise you'll be up for a new one I fear.
Re: Main loom.
Posted: Sun Feb 20, 2011 4:40 pm
Yes, the 12.48v although indicated as full on the charger, wasn't enough. An overnight charge brought that up to 13.05v, and unfortunately I'm still getting the clacking.
Jumped from the car, it was still clacking.
So, I'm guessing the battery and maybe something electronic is fried from the voltage spike with the loose -ve? The ICU?
Re: Main loom.
Posted: Sun Feb 20, 2011 5:41 pm
by Airbear
The battery should be ok. Just checked Brunhilde - 12.7V and no problems starting.
Starter solenoid would be my guess. Do you have a spare starter you can throw in?
Re: Main loom.
Posted: Sun Feb 20, 2011 5:43 pm
Airbear wrote:The battery should be ok. Just checked Brunhilde - 12.7V and no problems starting.
No unfortunately. Just spoke to BM Motorcycles, and he headed to that conclusion also. He didn't think there'd be a problem with the icu either.
Re: Main loom.
Posted: Sun Feb 20, 2011 6:35 pm
by Airbear
Ross Gregory might have a starter. (0421 057 488)
Hans might be worth a try if you want to borrow one while you fix yours. (0415 717 192)
Re: Main loom.
Posted: Sun Feb 20, 2011 8:36 pm
Thanks Charlie. I'd already emailed Ross.
I'm off to work this arvo, so no chance to follow up 'til late tomorrow night. I doubt I'll get this sorted before Friday, as mostly working . I hope I'm wrong.
I've been off getting stuff to securely tape up the loom that I've opened, and removed the starter cover. i cleaned the solenoid contacts, but that's all really.
Is there a way to remove the solenoid without removing the starter? In all my years riding these bikes, it's never been something I've had to do.
Re: Main loom.
Posted: Sun Feb 20, 2011 9:46 pm
by Deleted User 62
SteveD wrote:Thanks Charlie. I'd already emailed Ross.
Since you have the starter cover off, try testing the starter by using a screwdriver to short across the positive terminal (big wire from battery) to the other connector with a black wire on the solenoid. This bypasses the relay, switch, wonky wiring, etc.
Re: Main loom.
Posted: Mon Feb 21, 2011 1:21 am
by Bob Bennett
"Since you have the starter cover off, try testing the starter by using a screwdriver to short across the positive terminal (big wire from battery) to the other connector with a black wire on the solenoid. This bypasses the relay, switch, wonky
wiring, etc." As Tim said,
This would be a good fault locating procedure.
Re: Main loom.
Posted: Mon Feb 21, 2011 3:43 am
On an off chance, and unless you're absolutely sure of the condition inside the housing...
Before you start tearing the loom apart. its well worth dismantling the housing and checking the contact pins that mate with the offending multiplug to ensure that they are firmly attached to the board and electrically solidly connected. The multiplug is quite hard to insert and its quite possible for one or more of the pins to work loose.
