This is what my staintunes sound like with panniers fitted as these do alter the noise etc.
http://www.youtube.com/watch?v=Br68K6gacnw
I didn't think an earlier muffler would have more back pressure. I'd guess less because of a smaller engine...Motorhead wrote:Keep the Balance tube so even a little higher back pressure won't hurt if you jet right
besides a earlier muffer can have less back pressure depending whats inside so I'd be suprized if it did have more
Theoretically, given that the ports and pipes match, and all else being equal,jjwithers wrote:While we are on the topic of mufflers, i am thinking of adapting a set of mufflers to a /5 engine from an old BMW R12 (from the 40s). It will be more of a stylistic decision vs anything else.
Will the difference of back pressure be a cause for problems when it comes to tuning a /5 motorcycle with pipes meant for a smaller engine?
I can see it adversely affecting the horsepower a bit...?
Thanks
-josh
Can you elaborate a bit vanzen? I'm familiar with the balance tubes found between the twin carbs of a British vertical twin, and I believe that I understand why and how a balance tube works. And I certainly noticed the absence of a balance tube on my first airhead.vanzen@rockerboxer.com wrote:A piece of hose connected between the vacuum ports on the intakes
will do an effective job of "balancing" (vacuum) differences between cylinders.
