Are there better drill bits than cobalt?
Roy Gavin
Re: Are there better drill bits than cobalt?
Post by Roy Gavin »
Diamond lapping tools and knife sharpeners are not hard to find, Mine cost $10 around 20 years ago and still cuts OK.
On a larger drill it would probably do a good job cleaning up the undercut -better than I could do on a grinder anyway.
Roy Gavin wrote:Diamond lapping tools and knife sharpeners are not hard to find, Mine cost $10 around 20 years ago and still cuts OK.
I'm a big fan of diamond abrasives. I have a fine (sorry) assortment of whetstones, dremel cutters of various shapes, needle files, and even a bit of diamond paste which I'm looking forward to using if I ever discover a need great enough to actually use it. I've even got a diamond grindstone fitted to one of my bench grinders that I love for sharpening drill bits. But I've never found diamond abrasives very useful for removing "significant" amounts of metal. I suppose that's because "significantly" large diamonds are too expensive to use for coarse abrasives.
I'll be a happy camper when I find a large 200 grit and even coarser diamond whetstone (that I'm willing to pony up the bucks for). How wonderful it would be to do significant resharpening of things like planer or jointer blades without removing them from the machine. For smaller curved surfaces, like router bits, diamond wheels for a dremel work fairly well.
The Veg wrote:
Zombie Master wrote:I can't seem to get a year out of a toaster oven anymore!
I never knew I could get so enthusiastic about a toaster oven! :D
Yea, bu let's face it Veg, you are easily amused!
Ken in Oklahoma wrote: I have a fine (sorry) assortment of whetstones, dremel cutters of various shapes...
I'm (sorry), but does that mean you really have "a sorry assortment of whetstones,...) :mrgreen:
Ken's (sorry) was an apology to the women of the world for having bought diamond sharpening devices and depriving them of their best friends.
Major Softie wrote:I'm (sorry), but does that mean you really have "a sorry assortment of whetstones,...)
You know I'm not sure now. It made a lot of sense when I posted hours ago and the thought was fresh in my head. I seem to remember being concerned about a pun involving fine grit and whetstones.
Ken, fogged in in Oklahoma
Sunbeem
Post by Sunbeem »
I was lucky a while back, and came across a large stash of stones, covering a wide range of grades, and centre holes...
Most of my drill-bits will be over twenty year old, many much older.
After sharpening a drill-bit on my bench grinder, I usually dress it on the side of one of these, stone in one hand, bit in the other, holding it to the light, then finish off with a slip, (stone wedge) of very fine carborundum.
Sunlight and a jeweler's loop, or lens, makes life easier.
A two stone grinder will get you from a badly chipped bit, to a fairly sharp one, if you get the grades right, and quench repeatedly. The outer edge is very easy to overheat, and it takes all the pain.
If it turns red, you need to cut the end off square with an angle grinder, try again, and fail again ... but this time - fail better.
Blunt drills are freely available at car boot sales and garage sales. The older the better is not always the case, but I find disappointments are very rare.
If you're starting from scratch, have one sharp half inch/12mm to copy, and begin with your largest.
As I'm right handed, I hold the end in my left hand and with my right, guide the tip through a circular motion as I lift the end, all at the correct angle seen from above, and the side.
Look out for triple fluted bits, as well as being nice to use, they are invariably good steel. Check the flutes on used bits, the tip condition is immaterial.
Buying bits with heavy advertising behind them, and bold ingredients to the fore, should set alarm bells ringing.
Just avoid wasting money on new drill-bits, when the world is full of blunt ones that just need bloody sharpening.
It's not about what they are made of, it's more about what you are made of.
Sunbeem.
One day more -- one day less.
Great description!
Max Headroom
Post by Max Headroom »
Sunbeem wrote:I hold the end in my left hand and with my right, guide the tip through a circular motion as I lift the end, all at the correct angle seen from above, and the side.
Funnily enough, I'm left-handed yet I hold drills the same way as you when sharpening. Probably comes from years of using equipment and machinery designed for right-handers . . .
- Mark Twain
I'd like to see someone sharpen a drill bit holding the 'blunt' end in their right hand! :shock:
