Good tip thanks Dan. I will try it.Dan in IL wrote:You can get your carbs almost perfectly in synch by doing this......
Found at least part of the problem, one cable is catching at the carb top; the sheath not staying down on its seat. I need to do some re-routing and fit those little rubber sleeves. I've only just started a new job .. but a day off right now would sure be nice to do some tinkering.
