Re: what master cylinder piston size for 40mm ATEs?
Posted: Thu Sep 13, 2012 7:45 am
Just something to check which had me fooled for a while once. Besides air in the system excessive brake lever travel could also be due to the pistons retracting more than normal so that they have too far to travel next time the lever is pulled.
By getting up very close and carefully watching what was happening to the pads and disc as I applied/released the brake lever I was able to see that the disc itself was bending on brake application and then bending back on release, pushing the pistons back more than would be normal. We are talking about a small movement that was barely visible perhaps 5 - 10 thou but it was enough to cause excessive travel at the handle bar lever. In my case the underlying cause was that in spite of noting how they came out I'd managed to put the old pads back in the wrong way around. I assumed that the reason this caused the problem was the pads had worn slightly tapered rather than being exactly parallel. Swapped the pads around and the excess lever travel went away.
Your pads may be new but in principle worth a close up look at the calipers in action.
