I used a set of 36mm flat on my 1974 R90/6 and I'd offer thats the largest I'd use on any BMW
and again I say WE Americans over carb
But unless you cam the motor really a 34mm is all you need for a R100
Mikuni
Re: Mikuni
Motorhead wrote:I used a set of 36mm flat on my 1974 R90/6 and I'd offer thats the largest I'd use on any BMW
Even BMW went to 38mm slide carbs on the r90s with small valves and it was not
considered over carbed.
Re: Mikuni
Never saw proof of that..... I know of the 32mm Bing and the 40mm Bing and never saw any 36mm Bing or other carb installed or offered for trade or sale in any place I look for parts
nothing in my manuels eather BUT then lots of stuff can happen
Re: Mikuni
In general-
larger carbs favour higher rpm,
smaller carbs favour lower rpm.
Carbs that let you howl around a race track aren't necessarily going to make for a good real life ride.
Without other engine/intake modifications I would opt for 34mm Mikunis.
Rocky Point Cycle probably see it that way because their R100 kit contains 34mm carbs.
I wonder if anyone here has tried their kit?
Re: Mikuni
There is a kit for the R100 in IBMWR market site 34mm $95.00
Re: Mikuni
Stan @ Rocky Point used to only sell 32s for R75 to R100s. He now has a 34 kit for the R100.
Jetting info: http://www.braigasen.com/Mikuni_jetting ... stroke.htm
BTW, ZM I have a set of VM32s with cables if you want to just try them out.
Re: Mikuni
Garnet wrote:Stan @ Rocky Point used to only sell 32s for R75 to R100s. He now has a 34 kit for the R100.
Thanx G! It would be a cool project to tune a boxer strictly for good low rpm torque production. Who need HP when you can have lots of grunt!
