Page 8 of 12
back on track
Posted: Mon Aug 29, 2011 1:12 pm
by vanzen
1903 – Goodyear Tire Company patents the first tubeless tire.
1978 - Metzeler develops the first tubeless motorcycle tire.
Using a tube in a tubeless tire effectively LOWERS the tire's stated speed rating.
Re: back on track
Posted: Mon Aug 29, 2011 3:11 pm
Absolutely. The Speed Rating signifies the tire's ability to deal with the heat generated at high speed with full (or, at least, high) load: its ability to control heat generation, its ability to hold up under that heat, and its ability to disperse that heat. A tube both adds to heat generation and slows the dispersal of that heat. The only factor that I don't believe adding a tube affects is the ability of the tire to maintain integrity while subjected to that heat.
Re: tubeless
Posted: Wed Aug 31, 2011 1:49 pm
by twist
My tires have arrived and my wheels are ready but I cannot find the bloody valve stems in this city! Part stores HAVE to be given a part number to find anything, the part stores only stock sizes that are too large and the valve stem I did find at bike bandit had to be ordered and there is no telling when it'll arrive. I have a ride coming this week end and would like to scrub my tires in and sort out any bugs before I go. Is there any reason the rubber pull through valve stem should be avoided?
Re: tubeless
Posted: Wed Aug 31, 2011 2:09 pm
twist wrote:My tires have arrived and my wheels are ready but I cannot find the bloody valve stems in this city! Part stores HAVE to be given a part number to find anything, the part stores only stock sizes that are too large and the valve stem I did find at bike bandit had to be ordered and there is no telling when it'll arrive. I have a ride coming this week end and would like to scrub my tires in and sort out any bugs before I go. Is there any reason the rubber pull through valve stem should be avoided?
Only that it is designed for a specific thickness, and, since the Snowflake was not designed for such a stem, it's a complete crapshoot whether or not it is the correct thickness.
Re: tubeless
Posted: Wed Aug 31, 2011 3:52 pm
The rubber valve stem initially used in my rear wheel leaked, and had no strength.
Maybe use your tubes until an appropriate stem arrives.
Re: tubeless
Posted: Wed Aug 31, 2011 4:28 pm
by vanzen
Rubber stem – not advised.
Have you tried the BMW item intended for an 80s Y-spoke cast wheel ?
At 8mm, the stem hole may need to be reamed,
a simple task with a drill motor and an appropriate drill bit.
Re: tubeless
Posted: Thu Sep 01, 2011 1:49 am
by twist
the local BMW dealer here has become interested in new bikes only. They do stock a few airhead parts but only filters and basic maintenance items. They are zero help. I did find exactly 2 stems at a motorcycle shop by going in with a picture, (thanks vanzen), of what I was looking for. New stems are in nice and snug and the new tires go on tomorrow. Just in time to test it out before I go on a ride. Things always works out if I'm patient and have a positive attitude. Thanks to everyone here for the advice, information and opinions. Too bad we all live in different places, I would like to buy you all a beer and listen to you argue some more. cheers!
Re: tubeless
Posted: Thu Sep 01, 2011 2:53 am
Another point of interest with a tubeless flake, is that if one gets a puncture 'out there' and intends to use the little Co2 bottles to inflate the tyre, the bottles won't fit without a right angle adapter or right angle valve stem.
Re: tubeless
Posted: Thu Sep 01, 2011 6:06 am
by vanzen
ME 109 wrote:Another point of interest with a tubeless flake, is that if one gets a puncture 'out there' and intends to use the little Co2 bottles to inflate the tyre, the bottles won't fit without a right angle adapter or right angle valve stem.
I always carried an "engineair power pump" with my tire-plug kit.
Aerostich is one place that sells 'em.
Re: tubeless
Posted: Thu Sep 01, 2011 6:31 am
A very good option Vanzen, unlimited puncture repairs, and it has a right angle valve connection.
I've wondered a few times about a mini compressor. Silly bugger! I've got a great big one!
Anyhowz, I think I'd still take the Co2 bottles for a 'Whiskey smash' cocktail while I was fixin' the tyre.
