Wall thickness R80/7 swingarm
Posted: Fri Mar 10, 2017 3:22 am
Hi guys,
I'm redesigning the rear suspension of a R80/7 to a monoshock setup. I'm lucky to be able to do this as my master thesis. But I have to run some analyses on the swingarm. therefore I'll have to design it in CAD.
Is there someone who knows the wall thickness of the tubes used for the swing arm is I don't want to cut mine?
I could assume that the wall thicknes is the same at both sides (which isn't a bad assumption I think), at the side of the shaft it's about 4mm
and does anyone know the actual material it's made of?
Thanks in Advance!
Cuno
Thanks in Advance!
Cuno
