Ain't broke but...,
Ain't broke but...,
84 R100S So while I have things apart I was wondering; should I take coil wires and Spark plug leads off and do a clean up? I could cut a bit off the spark plug leads and reinstall with dielectric grease. Or am I courting a problem?
- Moderator
Re: Ain't broke but...,
I'd do a clean up just for preventive maintenance. On the cutting part, probably wouldn't hurt much; not much to doing it.
- Airbear
Rob, just so you know, dielectric grease is non-conductive. That is the point of it - it seals the immediate area around a conductive joint, preventing oxidation, etc
And the copper a-s does that and more! Providing one of God's favorite (affordable) paths for electricity.
That would be the God that favors mining from the ground and polluting our ecosystem.
- Steve in Golden
Re: Dielectric Grease
I've never used dielectric grease, perhaps I should be. I don't know much about it so I consulted the oracle of Google (Duane would be proud). Here's an interesting article about it.
Dielectric Grease vs Conductive Grease
Steve in Golden wrote: ↑Thu May 11, 2017 1:34 pm I've never used dielectric grease, perhaps I should be. I don't know much about it so I consulted the oracle of Google (Duane would be proud). Here's an interesting article about it.
So much for what I know!W8ji wrote:Both dielectric grease and "conductive" greases (anti-seize) are insulators. The primary difference between dielectric greases and "conductive" greases is that "conductive" greases and anti-seize greases include some amount of finely-powdered metal. The finely powdered metal is suspended by insulating grease, so it does not conduct. The suspended metal powder does lower the voltage breakdown of any arc paths through the grease.
- Steve in Golden
Duane wrote that page? Wow, he really gets around.
Shit!
I thought he had been busy. What with the "new look" on his website,
and from your mention of his name, I "assumed" that you had sourced his website...
edit: I edited my quote
Good read Steve thanx!Steve in Golden wrote: ↑Thu May 11, 2017 1:34 pm I've never used dielectric grease, perhaps I should be. I don't know much about it so I consulted the oracle of Google (Duane would be proud). Here's an interesting article about it.
