When properly lubed, the throttle tube (grip) on a /5, /6, or /7 shouldn't "snap' back, it should creep back. If it snaps back, it either means it's not lubricated properly (dry) or the springs in the carbs are too stiff. If your throttle grip isn't even creeping back, check that the grip isn't pushed too far onto the handle bar and is dragging on the end of the handle bar itself.
I was replacing my throttle cables on my 71 R75/5. I re-greased the cam, lined up the markings and attached the new cables. When I roll the throttle and release, it doesn't "snap" back, but slowly creeps back. Pretty much have all the slack out of the cables. I read the above on another forum, which says this is normal. I have mikuni VM carbs and the slides snap down when pulled up at the cable where it goes into the carb - so no hangup there. The stop screw underneath the throttle tube is loose (not grabbing), so that too is not holding the tube from returning to the idle position.
Bike hasn't been used in over a year due to recovering from an auto accident (old cables stretched), so I can't remember if this is correct or not. Is this right? Or the throttle suppose to snap back?
What else do I need to know?
Thanks...
