I've lifted this from BMBikes forum. It's an excellent article on how to loosen stuck lock wafers in the ignition switch. Hopefully no-one will need this info.
http://www.bmbikes.org.uk/Forum/viewtop ... 37#p174637
Stuck ignition switch
Re: Stuck ignition switch
But ignore the first reponse- do NOT use WD40 in a lock. It may help short-term but as it is mildly corrosive and can leave residues, it's not good long-term.
Cogito Ergo Moto
- George Ryals
A QUESTION OF LUBRICATION
Myth: WD-40® Multi-Use Product is not really a lubricant.
Fact: While the “W-D” in WD-40® stands for Water Displacement, WD-40® Multi-Use Product is a unique, special blend of lubricants. The product’s formulation also contains anti-corrosion agents and ingredients for penetration, water displacement and soil removal.
WD-40 is great for drilling,taping,machining, aluminum.
It doesn't leave a mess or stain like some other cutting and taping fluids.
If you need lube use Triflow with teflon.
+1
Corporate propaganda.
Cogito Ergo Moto
