Welcome to Airheads !! No clue as to what your
location might be, so it's not clear if you have another 3 months sitting around and tinkering (Michigan), or seriously ready to ride right now (Arizona) ?
In the intervening time some things have drastically changed... fuel for the
worse, and oil for the
better. These are changes akin to "night and day", and are going to drive some rather mandatory maintenance items....
• Fuel and the effects of leaving old fuel in the system is going to be your
Number 1 issue. You're going to want to dump ALL the fuel in the tank and carbs ASAP. The bike may start, but it's not going to run very well without new high octane fuel. Not just any fuel, you're going to want to research Top Tier fuels (
http://www.toptiergas.com/ ).
• Run time on the older fuel has probably damaged the spark plugs. Having a new, spare set of NGK BP7ES around would be wise.
• You'll also need an additional fuel cleaner and conditioner for at least the first year. I highly recommend Star-Tron. (
http://www.starbrite.com/item/star-tron ... e-additive )
• Oils have vastly improved, but most oils are not suited for
older engines, so you need to study before you leap to buy. You should be running a 20W50 oil in the engine, API rated SF or SG, like Valvoline VR-1. If it's cold, or for short term use (like your first ride), you can use 15W40 API rated CJ-4 diesel oil. The dipstick is NOT screwed into take the level reading. I seriously doubt you need to drop the oil pan, just drain the sump and refill. Due to the age of the oil seals, it's always best to use non-synthetic oils at first.
• The gearbox, drive shaft and final drive all use the same type "gear oil". Any name brand, non-synthetic oil will be fine, such as Valvoline 80W90. You may wish to buy a baby bottle or other small marked container to measure the 150cc for the drive shaft.
• DOT4 brake fluid has a maximum life of about 5 years,
and ideally should be replaced annually. Therefore your front brake system (about 70% of your total stopping power) will need extensive inspection
and fluid flush before hitting the road. Your front brake master cylinder and reservoir are tucked under the fuel tank. Even after the bike is being ridden (and brakes heated),
due to the extended storage, I would highly advise at least 2 more complete fluid changes.
• Your tires are not going to be road worthy after such an extended storage. Consider new tires and tubes on both wheels before riding. You can use the "vintage" tire sizes of 3.25-19 front/ 4.00-18 rear, or the newer metric sizing of 100/90-19 and 120/90-18. There are numerous brands that offer excellent tires in these sizes. The minimum tire is probably the
Bridgestone Spitfire S11. Avoid
Shinko.
• Mice have a long history of nesting in BMW air filter housings. "BMW" is German for
Bivouac Mice over Winter, or something to that effect. Anyway, at some point for a performance improvement, you'll want to pull the LH air filter cover and remove all the straw and chewed up paper.
Hope this helps.
