Front snowflake bearing 1982 R100
Posted: Tue Mar 20, 2018 3:26 am
by FMurtz
bit of play,going to replace bearings, any advice? which includes a breakdown pic of the shaft with all bits on it,I have a factory manual but can not find it.
Re: Front snowflake bearing 1982 R100
Posted: Tue Mar 20, 2018 4:33 am
by barryh
It may just need the pre-load adjusting but inspection, clean and re-grease before hand is the minimum that should be done. There is no short and quick guidance on how to do this. Take a look here: http://w6rec.com/bmw-motorcycle-wheel-b ... pun-hubs/ or here http://bmwmotorcycletech.info/section4.htm
Posted: Tue Mar 20, 2018 10:51 pm
by Wobbly
First thing to do is to verify that you have steel bearing seats in your cast wheels. You can easily do this with a magnet. The reason is that the early, all-aluminum wheels have a MUCH different bearing replacement procedure.
