20mm black EBA foam. Replaces a rapidly deteriorating oem one.
Dual seat under the cowl foam.
Re: Dual seat foam.
It's the bit that goes under the seat cowl and seals the rear storage compartment when the seat closes. #12 @ the bottom of the diagram.
Re: Dual seat foam.
Got it....looks good! I have one of those on my R100
Re: Dual seat foam.
When you are recovering a seat a layer of soft 10mm foam stuck to the old pad with spray adhesive make fitting the cover easier and improves the comfort too.
Some top quality auto seats are made that way, as I discovered when my best mate pulled a hissy when he was left in the car outside the bar----------------.
