Newby, no spark
Posted: Sun Jan 26, 2020 1:51 pm
Greetings all,
Recently picked up 2 airheads (1970 r50/5, 1973 r75/5, plus an r60/6 Motor). Been wrenching on all things internal combustion for a couple decades now. Have owned several antique, vintage cars, mc’s. These are first. BMW’s. After cleaning out the mouse house’s, soaking cylinders, now seeing if I can get spark. I’ve read a lot on various sites and know the following: 1970 r50 - By jumping starter relay, engine spins. I have 12 volts at coils, 12 v at live side of points. Ground side of points is at ground. New condenser, new points. No spark, however, if I I manually open/close points I get good spark at spark plugs. With battery disconnected, if I measure across points I’d do see they are opening and closing. I am stumped as manually opening closing points I get good spark. Would think with starter running would see same. At this point I am not trying to get the engine to run, just want to see spark at plugs.will then figure out timing etc....
Thanks for any suggestions.
