tire size
Posted: Mon Feb 03, 2020 3:37 pm
by Zombie Master
1984 R100
Can you guys tell me what is the correct tire spec for snowflake wheels?
Is there a difference in specification between tire brands for these wheels?
Re: tire size
Posted: Mon Feb 03, 2020 6:04 pm
This site says front 3.25x19 and rear 4.00x18.
http://www.bmbikes.co.uk/specpages/R100.htm
Re: tire size
Posted: Tue Feb 04, 2020 10:07 am
Kurt in S.A. wrote: Mon Feb 03, 2020 6:04 pm This site says front 3.25x19 and rear 4.00x18.
Yup, that's the spec for everything from the 1969 R50/5 to the 1984 R100Rs with the exception of the R45/R65 models which have a
18" front wheel. Imperial size tyres are still available but some people who have gone with metric 'equivalents' find problems with rear wheel/ swing arm clearance dependant on tyre type.
Re: tire size
Posted: Tue Feb 04, 2020 10:39 am
by barryh
Zombie Master wrote: Mon Feb 03, 2020 3:37 pm 1984 R100
There are differences particularly if you go metric.
A 4.00 x`18 rear will typically be 671 mm diameter and have a mounted width around 110 -115 mm
110.90's will typically be 15-20 mm smaller in diameter and a similar width to the 4.00 so no rubbing problems on fitment but a small change in effective mph/1000 RPM.
120/90 will typically be a similar diameter to a 4.00 but up to 125 mm wide which can rub on the swinging arm.
If that isn't enough, some manufacturers seem to construct their 4.00 x 18 in the same mold as a 120/90 and just change the designated size to 4.00 so you find a 4.00 to be bigger than expected.
Re: tire size
Posted: Tue Feb 04, 2020 3:12 pm
by Zombie Master
Thanx🎯
Re: tire size
Posted: Sat Feb 29, 2020 6:35 pm
by lrz
It's time for a new set,so I've been shopping.
Figured I'd getaway from metric Spitfires for a change this year...
In rears, it looks like Avon Roadrider no longer offers inch sizes and even the Metzeler Lasertec from MAX has gone metric ??
https://www.rockymountainatvmc.com/ti ... cle-tire-p
https://shop.maxbmw.com/fiche/DiagramsM ... d=07242017
Or am I missing something?
Re: tire size
Posted: Sat Feb 29, 2020 9:36 pm
by jagarra
Michelin makes them in inch sizes for the BMW https://www.bikebandit.com/tires-tubes/ ... 3?m=143994
Re: tire size
Posted: Sat Feb 29, 2020 11:21 pm
jagarra wrote: Sat Feb 29, 2020 9:36 pm Michelin makes them in inch sizes for the BMW https://www.bikebandit.com/tires-tubes/ ... 3?m=143994
Excellent tyres Michelin but difficult to mount and seat. Be prepared for a tad more psi.....
Re: tire size
Posted: Sun Mar 01, 2020 4:46 am
Metzler lasertec and ME77 are still around in imperial sizes... in the UK at least. In fact, Max actually list them on their site...
https://shop.maxbmw.com/fiche/PartsDeta ... T_ME77REAR
https://shop.maxbmw.com/fiche/PartsDeta ... ASERTECH_F
Though to my eye, they look a bit on the expensive side. You may well get a better deal by going to a specialist tyre seller...
Re: tire size
Posted: Sun Mar 01, 2020 8:06 am
by lrz
Those are tough to spoon.
Regarding MAX, it is also noteworthy to me that they've stopped offering Avon tyres; at least as per the /7 fiche.
If metric has become common, probably I'll stick with Spitfires since they are a known quantity.
I seem to recall inch sizes were readily available the last time I was shopping which,iirc,was Spring 2018...
