Page 1 of 3
Those butterfly shaft screws...
Posted: Wed Dec 22, 2010 7:36 pm
by dougie
I have heard of various methods of securing them.
Backing them up on something solid, peen them with a pointed punch.
Or slot the end and hit them with a tapered punch.
It all sounds risky to me. One slip and it gets expensive.
I am considering just making them good-'n'-snug and using RED Loctite.
What do you folks think?
Re: Those butterfly shaft screws...
Posted: Wed Dec 22, 2010 8:29 pm
New screws done up tightly don't seem to give much trouble.
A pita when a screw head is damaged so new ones each time is the way to go (for me)
Posted: Wed Dec 22, 2010 8:50 pm
by dougie
ME 109 wrote:New screws done up tightly don't seem to give much trouble.
Thanks Jeff.
I bought new screws. Six of them. (I know myself that well)
Posted: Wed Dec 22, 2010 8:54 pm
by moore84rs
If you use Red Loctite; I suggest you apply a small amount to
the last few threads in the shaft, opposite the head.
To remove them you will need to heat the end with the Loctite above 400 degrees.
You want to heat the head as little as possible. If you heat it to the annealing
point of the brass the slot will be even easier to strip out.
Posted: Thu Dec 23, 2010 1:10 am
by Garnet
I have only had the butterfly srews out once, but them came out easily. After replaceing them I just gave them a light tap with a punch and they have stayed put.
The shaft and screws are brass and it takes very little effort to put enough of a mark on them to keep the screws in place.
Posted: Thu Dec 23, 2010 7:03 am
by dougie
moore84rs wrote:If you use Red Loctite; I suggest you apply a small amount to
Good point about the annealing. Thanks, I didn't think of that.
I am going to use Loctite 243 instead.
Posted: Thu Dec 23, 2010 10:10 am
by dougie
Garnet wrote:I have only had the butterfly srews out once, but them came out easily. After replaceing them I just gave them a light tap with a punch and they have stayed put.
Both the old and the new screws I have, are not brass. They stick to a magnet.
Posted: Thu Dec 23, 2010 10:43 am
by Garnet
Maybe it's my brain that is brass. :?
Posted: Thu Dec 23, 2010 1:36 pm
by George Ryals
There is nothing on an airhead that needs RED loctite...including carb butterfly screws. Just snug the screws down and give them a little ding with a center punch. Of course support the shaft while doing the ding.
Posted: Thu Dec 23, 2010 1:43 pm
by dougie
George Ryals wrote:There is nothing on an airhead that needs RED loctite...
How about you '69 BSA? ;)
