BMW R100R Bosch R6 plugs
Posted: Sat Aug 05, 2023 6:06 am
Hi Everyone,
Forum and airhead newbie here. I'm gradually going over my '95 R100R Mystic and finding a lot to keep me busy in the garage!
One of the last things on my servicing list was to find two black, sooty spark plugs on removal.
They're Bosch R6 and I could find no reference to these being used or recommended on my model.
Snowbaum does not recommend resistor type spark plugs and says that "... If you install both resistor plugs & resistor caps, your spark can become too weak to reliably fire the mixture 100% of the time, particularly in later leaner-running Airheads."
I believe resistor caps are standard fitment and I'm not sure if I have resistor spark plug caps or not. I will try to check this, but on looking for replacement plugs, quite a few options came up. NGK BP6ES seems a favourite although some recommend going cooler to a BP7ES. Then there's an Iridium option.
Which has worked well for you?
