Bing Type 53 Accelerator Pump Question
Posted: Wed Sep 25, 2024 1:51 pm
I'm helping a buddy with the stock Bing Type 53 (26mm) carbs on his '72 R50/5. We're rebuilding them and I see there is an accelerator pump as part of the main jet/mixing tube assy.
I'm curious how this actually works so I can verify it's operation when re-assembled.
I'm very familiar with Dellorto PHM carbs (R90s) and their accelerator pumps, as they use a specific jet to squirt fuel when the throttle is opened, via a small lever that slides on the carburetor slide. So its easy to verify a stream of fuel being squirted when the slides are raised.
But the Bing's have a much different setup, using a small spring loaded wafer/disc inside of the mixing tube.
Thanks for any guidance/explanation.
RPGR90s
RPGR90s
