Hello,
I am helping a friend get her '77 R100RS running and rideable so she can sell it and I have run into a couple issues. First off are the brakes. The brake fluid was pretty grim so I pulled the calipers and took them apart (a link to a video about the bike is below). I expected to find the pistons rusted, but they looked much better than I expected (except the recesses on the side that presses into the back of the pads). I ordered new seals, pads, o-rings and and pressure switch (that was dead too) and started reassembly. When it came time to slide the pistons into the caliper, they didn't want to go in. I lubricated both the new oil seal and the walls of the piston with brake fluid, but it was way harder to press them in than I've ever experienced on a brake rebuild. Now that I'm at a point where I'm trying to bleed them (still working to build pressure, but had to take a break), they grab the disc, but don't fully release. When you let go of the lever, the wheel will turn with force, but mot easily. Is this normal? Am I missing something?
As mentioned, I had to take a brake from trying to fully build pressure (hoping there isn't a master cylinder rebuild in my future). While taking the break, I figured there was enough pressure that I could confirm the brake light switch is at least working and that the brake light would now come on. When I turned the key, I found the battery was completely dead. It is only a few weeks old and shouldn't be unless there is something drawing on it.
It was so low that at first I couldn't even get the battery tender to charge it (just gave the flashing red "not charging" light). I gave it a bit of a boost from a jump pack and tried the battery tender again. Now it was at 4v and giving a solid red light indicating it was charging. After a bit of puttering with other things, I heard a re-occurring clicking sound. It sounded like a relay and I confirmed it would stop if I disconnected the battery negative. I traced it to the horn relay that sits to the left of the master cylinder by the frame. Previously (in the video below), the horn wasn't working until had pushed on that relay a bit. I think the reason it is clicking is that the voltage is so low it can't hold the relay contact closed and it keeps falling back to open and I didn't hear the clicking before because the battery had enough power to just hold the relay closed. Now I need to figure out why there is power at the relay when the key is out of the ignition. I'm sitting down with a wiring diagram to try and figure it out, but if anyone has any ideas or think they can point me in the right direction, I'd love to hear them.
https://youtu.be/4Y9jugE1g-o?si=UNZRxbcJeZd-akFZ
Many thanks,
jason in Seattle / 6 Bike Garage
1977 R100RS - brake and electrical questions
6bikegarage
6bikegarage
Re: 1977 R100RS - brake and electrical questions
after studying the wiring diagram I'm, if anything, more confused. If I understand the relay operation, when you press the horn button on the switch gear, it completes the coil circuit in the relay, which closes the gate and allows battery power to flow to the horn. Power can't get to the horn button unless the ignition switch is on. If the clicking I heard was the the relay activating, what was triggering it. The ignition was off. if somehow, there was a short allowing power to the button, the button doesn't seem stuck and if it was, wouldn't that keep the continuity from the battery to the horn and the horn sounding?
Also, wanted to ask one other thing about the brakes. The pads closest to the wheel (opposite the caliper piston) have a paper clip like wire retainer. This doesn't feel very secure. It has a pretty good bow to it and it feels like it could slip off the notch on the brake pad post. It's holding right now, but it doesn't seem right. Am I missing something there too?
Thanks for any help.
Cheers
Cheers
It sounds to me like there is something basic wrong electrically. It also sounds very much like the battery has been run completely flat and there is a good chance that it has been damaged. Try charging it fully (off the bike) and see if it will hold a charge.
You need to go through the wiring... do you have any idea what the condition of the bike when it was parked up... that might give some clues. One thing is for sure. There is no way the horn relay will be actuating with the ignition off unless there is something wrong with the way things are connected up. This may also explain why the battery has been flattened
Unless you are willing ( and dare I say, competent) to go through through the wiring systematically and sort it out from basics, I think you may have to use an auto electrician.
The brake also doesn't sound good. The piston should be fairly free in the caliper when there is no fluid in the system. If the system is full, there will be some resistance but it should retract enough for the wheel to spin freely (with perhaps just a very slight sound of contact). It certainly shouldn't require any great force to turn the wheel...
Sorry if that's not much help. It's difficult to make any realistic diagnoistic without a lot more information or access to the machine.
At the end of the day, it may be better to advise your friend to sell the bike as a non-runner than to enter into a possibly protracted and expensive series of repairs.
6bikegarage
thanks for response. I've been studying things and I think the relay may be the issue. Power is supposed to go through the ignition to the button. When the button is pressed, it allows the power to flow through the relay to ground. This energizes the coil creating a small electromagnet that closes the "gate" an allows power to flow straight from the battery to the horn and ground. I think that the "gate" was sticky and not falling back to it's full open position. Sitting in close proximity to the contact could allow the power to build and arc across the gap (the regular clicking I was hearing was more of a zap). I ran this theory by a friend with way more electrical knowledge than I have and he agreed that it is likely what is happening. I'm charging the battery and will see if it holds a charge and then I'm going to replace the relay and watch for any voltage drop.
the brakes are a weird one. They are the same pistons and calipers that were with the bike. Its almost like the oil seals are wrong, but I got them from a reputable BMW parts site and they visually fit the caliper bodies perfectly. I might have to drain fluid and break them down again. Hmmm.
6bikegarage
I got a new relay finally and now believe someone had it wired up incorrectly. I diagramed what I have so I could compare it to the wiring harness in the clymer manual. Everything on the starter relay makes sense and looks right (except the green wire which is supposed to be red), but I think someone replaced it with a green wire to tie to the horn relay and maybe mixed up the terminals when they did. I think I just have to figure out how to de-pin the brown and green wires and swap them so the green goes to 30 and the brown with white goes to 85 (though as the starter relay goes to ground through 30, maybe that is where the black wires to the horns should be and the green should go to 87...hmmm).
If anyone is familiar with these, can you confirm that:
A) The horn relay should be 4 pin (the socket for 87A on that terminal appears to be blocked with a solid piece of plastic)
B) the brown with white goes into 85
C) the red wire to the clock should connect to wherever I put green (though I may replace with a correct red).
Many thanks,
jason in Seattle
Many thanks,
jason in Seattle
- horn relay.jpg (93.19 KiB) Viewed 4968 times
A light dawns...6bikegarage wrote: ↑Tue Dec 30, 2025 8:16 pm I got a new relay finally and now believe someone had it wired up incorrectly. I diagramed what I have so I could compare it to the wiring harness in the clymer manual. Everything on the starter relay makes sense and looks right (except the green wire which is supposed to be red), but I think someone replaced it with a green wire to tie to the horn relay and maybe mixed up the terminals when they did. I think I just have to figure out how to de-pin the brown and green wires and swap them so the green goes to 30 and the brown with white goes to 85 (though as the starter relay goes to ground through 30, maybe that is where the black wires to the horns should be and the green should go to 87...hmmm).
Many thanks,
jason in Seattle
Assuming the terminal names you show in your image are from the relays themselves, you have the wrong starter relay. The fifth terminal on the starter relay should be marked 87, not 87a. BMW themselves made the mistake in their original wiring diagrams which were copied by Haynes and the only reason that Clymer can claim to be right is that they don't show terminal designations at all.
The correct relay, as I say, should have two terminals marked 87. These are permanently connected together inside the case. The power to activate the relay itself, goes through these connections so nothing on the bike will work with that relay in place.
You may be inclined to desregards this, after all, BMW made the bike so, of course, they got it right... all I can say is even if you don't believe it, check it out. If you follow the wiring diagram, you'll find that, all of a sudden it makes sense... of a kind.
The full story (or as much of it as I know) is...
For some reason, lost in the depths of time (well, at least I don't know what it is), when BMW upgraded the wiring for the /6 series, they decided to route all of the power for the whole bike through the starter relay. For some reason they wanted the two red wires (one from the battery and the other to the ignition switch) to be connected to seperate terminals at the relay with the terminals permanently connected together. They also found that a suitable standard relay was available if they ignored the DIN standards for terminal identification. which state that terminal 30 should be the contact power connection and that 87 (87a, 87b) should be connections out to the controlled circuit(s).
The simplest way to check if this solves your problem is to remove the wires from the 87a terminal and connect them temporarily to the wires connected to the 87 terminal. If there are no other issues, the bike should spring into life... In fact if you chose to make that arrangement permanent, you would simply be upgraging the system to approximate that used on the early R45/R65 models.
If anyone knows or can think of a reason why BMW chose to use such a non-intuitive and non compliant wiring system, I'd love to hear it.
