K75 Fork Internals
Posted: Sun Aug 15, 2010 9:46 am
by Nourish
I have just purchased a pair of used K75S fork legs and have pulled them apart for inspection and have enclosed a couple of pictures of the left hand one. The very light spring on the valve is accompanied by two O rings and one of them is wrapped around the spring - I can't believe that this is correct - where should these two rings fit? and secondly the two large compression springs have a nylon spacer between them and a slightly larger on e at the very top - the parts fiche shows only one spacer - what is correct? These forks are going to be fitted to my naked R100 and came from a faired bike so some adjustment will be needed for to the ride height. Thanks for your thoughts.
Re: K75 Fork Internals
Posted: Sun Aug 15, 2010 12:52 pm
Well, two things.
First of all, you know there were two different K75 forks, right? Showa and (I believe) Sachs. So, you have to be looking at the right parts fiche for those forks.
Second, there were many spring kits available for the bike from the aftermarket, so you can't assume anything about how the springs are supposed to be arranged.
Posted: Mon Aug 16, 2010 5:21 am
by Nourish
Thanks for the reply Major, these leg bottoms are Brembo and were cast in 1985. Cheers
Posted: Tue Aug 17, 2010 3:06 pm
by Jeff in W.C.
the internals look similar to my forks on my 88 R100 RT. I do believe one of those O-rings goes in the grove on that piece just to the left of the small spring in your photo.
Posted: Tue Aug 17, 2010 6:17 pm
by Nourish
Thank you Jeff - I think your right - So what do they do?
In case any one wants to make a note The Sachs stanchions measure 1.627" and the Showa ones 1.612" - I have the Sachs ones. Cheers
Posted: Tue Aug 17, 2010 7:49 pm
by Jeff in W.C.
Nourish wrote:Thank you Jeff - I think your right - So what do they do?
I believe those parts make of the valve portion of the damper, but I'm really not an expert here. Hopefully someone with more knowledge will speak up confirming or correcting my statement.
