custom swingarm caps?
jjwithers
Post by jjwithers »
Does anybody know of a source that makes custom swingarm caps? I've seen them with a BMW logo on there but often wondered about adding something else there.
I guess you could always glue something into the cap...
www.beemersandbits.com
'66 R60/2
'72 BMW 2002
Instagram - jj_withers
r90s
Re: custom swingarm caps?
Post by r90s »
You can make your own:
Jon-Lars
Beverly, WA
http://s44.photobucket.com/albums/f13/R90S/
jjwithers
Post by jjwithers »
Very cool! what did you make them out of?
my machining tools are very very limited.
'66 R60/2
'72 BMW 2002
r90s
Post by r90s »
My skills are limited, too.
Dick Casey made these for my R80G/S project. He turned them from billet, added an o-ring groove to lock them in place, and installed the emblem.
Maybe he would make some for you, if he has time.
There was a guy from here in Melbourne, Oz, that had made a BMW hub cap cover for the 1150 models. He sold them online and made enough money over a few years to buy a brand new R1150rt (from memory)
I doubt the demand would be there for the swingarm cover, and the flash ones shown above might be spendy to make too?
Never know, they might fund a future project?
jjwithers
Post by jjwithers »
who's Dick Casey?
I'm thinking a C&C machine might be able to make these... or something similar.
also, on a separate note, would the threads of a /2 chrome swingarm cap fit on the swingarm pivot bolt? i am guessing it isn't an adequate substitute for the 27mm nut though... or is it?
'66 R60/2
'72 BMW 2002
Roy Gavin
Post by Roy Gavin »
You could probably modify the end caps from a pair of 1" cruiser grips to fit the existing caps - a skull and crossbones would look nice ---.
beemersanducs
Post by beemersanducs »
Just to let you know my machinist and I are designing a set that will look very similar to the ones pictured, I will let everyone know when there done. If someone is interested in a set let me know.
Post by Deleted User 287 »
Roy Gavin wrote:You could probably modify the end caps from a pair of 1" cruiser grips to fit the existing caps - a skull and crossbones would look nice ---.
+1
vanzen
Post by vanzen »
jjwithers wrote:who's Dick Casey?
A very well respected BMW builder – and an accomplished machinist.
jjwithers wrote:I'm thinking a C&C machine might be able to make these... or something similar.
"CNC" (Computer Numerical Control) is used to describe any machine tool
that is controlled by computer software.
The primary advantage of CNC vs a skilled machinist will be per/unit cost in mass production.
Someone with the skills of Dick Casey can certainly do without such modern amenities.
Essentially, what is needed to fabricate such a swing-arm decoration
is a lathe - and then the experience / skill to use it !
The nut, however, is not a decoration, and provides a specified torque for the S-A, pins, & bearings ...
I'd suggest not removing it ...
