Replacing pushrod tubes
Posted: Wed Mar 16, 2011 8:30 am
by aharrett
I need to replace a leaking pushrod tube on my '79 R100. Haynes just says push the old one out, I have tried in the past to move one, and they seem pretty immoveable. What's the technique, heat the barrel up in an oven and then press?
Re: Replacing pushrod tubes
Posted: Wed Mar 16, 2011 10:40 am
by Garnet
Hans @ Hucky's sells a drift,
http://www.bmwhucky.com/010071.html for the job or you can make one if you have a lathe. A mechnic friend has a universal drift set that has the right size in it and that is what I have used.
A little heat would help, but I would not go above 250 ish F. Hopefully some PO has not glued them in with some magic snot.
