New guy intro
Posted: Thu Mar 24, 2011 1:13 pm
				Hey all,
My name's Brian, and this is my '74 R90/6. It was in great stock shape, with low (~10K) miles that was sort of a garage queen and needed only fresh fluids, grease, and tires to be a nice rider. I also added Works rear shocks and front springs sprung for my weight (~220lbs in full gear) But, the gauges disintegrated on the first long ride, it had a 32/9 rear end that was really too steep for my liking, and the stock front brake wasn't good enough for me, even after new pads, fluid, SS line, and proper allignment. I swapped in a 32/10 (much better) and found a /5 speedo that had a ratio to match luckily, which I liked the look of better. For the brakes, I'm swapping the front end for a complete K100RS setup I found fairly cheap on fleabay. I wanted to keep the spokes, so after talking with Woody's Wheels about it I tracked down a hub for an R100R that they're going to lace to a standard tube-type rim. The only problem is caliper clearance, but I'm hoping that between the slightly narrower spoke placement on the R100R hub (than the stock /6's) and using a standard style rim I might be okay. If it comes down to it, I figure can shave the mount tabs and calipers and pick up an 1/8th inch or so overall, but I'll have to wait till the wheel comes back to see what I need to do. If anyone's done this, I'd welcome any input! Sorry for the crappy pics, these are a shortly after I got it and it's totally torn apart at the moment with the front end work.
Thanks, looks like a great forum!
-Brian
-Brian
