VoltageDropToDeath
Posted: Sun Apr 03, 2011 9:10 am
by 724thomas
My '82 R100RS has been running perfectly for many years with all the standard flaws and repairs. I,m not "electrical" so need some guidance. Over the last month I've noticed by VDO volt meter slowly dropping over a period of about 100 miles. A night on the trickle charger brings it back to life. Yesterday after an average ride the battery dropped to the point that it would not turn the starter. One suggestion was bad brushes or dirty contacts. I've ordered brushes but suspect there might be more. I'm open to suggestions on what to look for while I have the cover off. Thanks for any help..TomJ
Re: VoltageDropToDeath
Posted: Sun Apr 03, 2011 11:35 am
What's happening at the battery terminals when you hook up a good voltmeter and start and rev the engine to 3K RPM? You should see well in excess of 13v, best if it were above 13.5v. How old is the battery...maybe it's just gone.
Rather than just throwing parts at this, you should get the small book from Rick Jones at Motorrad Elektrik that helps you to troubleshoot the system and find the problem. It could be brushes (how many miles on the brushes), it could be rotor, could be regulator, could be diode board, could be corrosion in the cables, could be your negative ground to the battery is not tight at the tranny (don't over tighten).
Posted: Sun Apr 03, 2011 12:13 pm
My first step would be to confirm what the volt meter is showing you. I would put a voltmeter on the battery post, not the terminals. I have many times seen a voltage drop between the terminal and the post to which it is bolted.
Do not just go the shotgun route, or you should expect to spend (waste) a lot of money and experience a great deal of frustration. Electricity is pure science and can be tested, although not always easily.
Consider it likely that you could have more than one problem.
Posted: Sun Apr 03, 2011 3:05 pm
by Ken in Oklahoma
724thomas wrote:My '82 R100RS has been running perfectly for many years with all the standard flaws and repairs. I,m not "electrical" so need some guidance. Over the last month I've noticed by VDO volt meter slowly dropping over a period of about 100 miles. A night on the trickle charger brings it back to life. Yesterday after an average ride the battery dropped to the point that it would not turn the starter. One suggestion was bad brushes or dirty contacts. I've ordered brushes but suspect there might be more. I'm open to suggestions on what to look for while I have the cover off. Thanks for any help..TomJ
From reading your symptoms it is very likely that your charging system isn't working. I know that probably sounds obvious, but the fact that you can charge your battery over night and all is well for a while suggests the charging system. If your battery is very old or suspect now would be a good time to take your battery to a battery store where they can do a load test on it. They will be able to tell you if the battery is in need of replacement.
But, as I said, your charging system is the prime suspect. Your charging system consists of the alternator, the diode board, the voltage regulator, and the wiring connecting these things together and to the battery. Your task is to identify the culprit in a methodical manner.
Do you have a good repair manual? If not you need one. The manual will address the charging system and will be useful in helping you to isolate the problem.
The first and easiest test to do will to see if it is the voltage regulator is bad. For that you will need to lift your tank and find the voltage regulator on the R/H side, mounted to one of the two top frame tubes. The voltage regulator is a plug in. You will need to pull the regulator out of its socket and work with the socket itself. The repair manual should tell you how to use a piece of wire to make a connection between two terminals in the socket. I believe they are the D+ and Df terminals. By connecting the two terminals you are bypassing the voltage regulator and making the charging system charge in full. By making the connection you are applying the full battery voltage to the field windings in the alternator.
You will want to put a voltmeter across the battery terminals as Duane has suggested. Measuring there avoids the voltage drop to the voltmeter on your bike and tells you what you really want to know--what's happening at the battery. If you don't have a digital voltmeter, buy one. They don't cost much money, and they are regularly on sale dirt cheap at Harbor Freight.
With the voltmeter across the battery terminals, start the engine and watch the voltage. You won't need to put the tank back on. You will have plenty of gas in your carb float bowls to do the test. When you start the engine rev it up to about 2,000 RPM. You should see the voltmeter reading well over 13 volts (make sure your battery has been charged before you do the test). If you read a good voltage you know that the charging system can deliver the correct voltage with the voltage regulator operating properly. The one you took out isn't. You will need a new voltage regulator. They are expensive.
If the voltage doesn't rise as it should with the jumper wire, you have a problem elsewhere in the system.
I'm going to stop here because what you discover will guide your next step. If you do the test, post your results. And while you're at it, how about giving us any additional information we might want to know, such as the age and condition of your battery, any prior charging problems you may have had in the past, and what things you've done already in chasing the problem. We're capable of sorting out the information you give us if it isn't pertinent.
One more thing before I go, if your troubleshooting ends up with you needing to check your diode board, Rob Frankham has an excellent procedure on his web site. I use it myself.
Posted: Sun Apr 03, 2011 3:40 pm
by 724thomas
Ken, You won't remember because it was 8 or 10 years ago, but I had a problem I couldn't solve (on the same bike)and was ready to spend some big bucks on some major parts, and you told me to do a simple test on the carbs, which worked and saved me a gazillion dollars. That's a lot since I am semi employed at $5.67 an hour. This bike has been my only transportation for twenty years. I refuse to give up my bike for a run down car. Anyway, thanks for the starting point and I hope it turns out as easy as last time...Thanks again.TomJ
Posted: Sun Apr 03, 2011 4:17 pm
by Ken in Oklahoma
Well, TomJ, good to hear from you--again. No, I don't remember, sure enough. I don't think my memory goes back that far. :)
Posted: Sun Apr 03, 2011 4:37 pm
by Deleted User 62
You can get an OEM regulator for cheap at http://www.eubmw.com
Posted: Sun Apr 03, 2011 6:22 pm
Is the GEN light behaving normally?
Posted: Sun Apr 03, 2011 11:56 pm
SteveD wrote:Is the GEN light behaving normally?
Oooo, nice catch Steve. It's a painfully obvious question that none of us were bright enough to ask.
Posted: Mon Apr 04, 2011 12:01 pm
Ken in Oklahoma wrote:Well, TomJ, good to hear from you--again. No, I don't remember, sure enough. I don't think my memory goes back that far. :)Ken
My memory deletes automatically at 5 years, or is it 5 minutes?
