Gentlemen, check your balls. and ladies too.
Posted: Sat Aug 21, 2010 9:36 pm
We've all heard about ME109 blowing his crank because of a broken oil filter housing pressure relief spring.
I think it happened to a few other forum members also. It's very rare.
Anyway, since hearing his story I kept telling myself that I should check mine,
but I always forgot to.
Hell, I didn't even know there was one until ME109's story appeared in the headlines.
I had a new ball and spring, but not the retainer, the retainer has been on back order for a while.
SOOO..today after smashing my engine back together, I changed my oil and filter.
I poked the ball with a screw driver to test it, and it offered virtually no resistance.
It was like the spring was way to soft.
I started to unsrew the retainer; it was completely loose, it had never bin peened into place to lock it,
it came out really easily within about a turn and a half! It almost fell out by itself.
This is a new one (left) beside my 399,000km spring. Same amount of coils.
It didn't break like ME'109's, it had just shrunk.
That, combined with the loose retainer was a disaster waiting to happen.
I highly recommend that you all check this at your next filter change. might save you a lot of cash down the road.
If the spring breaks you might scrap your crank.
If the spring weakens or the retainer falls out, your oil will bypass the filter, and possibly your oil cooler.
I wonder how long I've been running on mostly unfiltered oil?
Luckily I change my oil way too often so if some by-passes my filter it's no big deal.
BUT . maybe a piece of crap in the oil that didn't get filtered was fed to the crank and caused this:
Guess I'll never know.
