Servicing disc type breather.
Posted: Mon Aug 23, 2010 3:19 pm
by Garnet
My 72 R75/5 winter beater needs it's breather serviced. It seems to be leaking from the front and rear main seals which are new, plus I also blew out a valve cover gasket, which I have never seen happen before.
Most articles on this subject say to simply replace the disc style breather with the later reed valve version.
Has anyone out there used an automotive PCV in place of the breather?
Re: Servicing disc type breather.
Posted: Mon Aug 23, 2010 3:28 pm
Not sure they'd fit under the housing. Why go out of your way when a decent drop-in part is readily available??
The old disk can be replaced with a similar dimensioned piece of PC board. Oak Okleshen used to do that a lot...I believe he doesn't have any more of the disks. They are 27mm in diameter. The hole in the middle is a #2 size drill bit.
Posted: Mon Aug 23, 2010 7:57 pm
by Garnet
Kurt in S.A. wrote:Not sure they'd fit under the housing. Why go out of your way when a decent drop-in part is readily available??
Cuse I'm cheap......................
Posted: Mon Aug 23, 2010 8:07 pm
by 00weel
A true Airhead enthusiast embracing his inner cheapness!
The only way to fly! :lol:
Posted: Mon Aug 23, 2010 10:49 pm
by standswithabeer
the breather disc is held shut by little, weak coil spring. is yours stuck shut, building sufficient crankcase pressure to blow out your front and rear main seals and valve cover gasket? wow.
Posted: Mon Aug 23, 2010 11:59 pm
by mattcfish
standswithabeer wrote:the breather disc is held shut by little, weak coil spring. is yours stuck shut, building sufficient crankcase pressure to blow out your front and rear main seals and valve cover gasket? wow.
Actually I believe if the valve is stuck open the engine will actually suck in more air than it pushes out, thus increasing crank case pressure dramatically. I doubt a valve can stick shut.
