Battery histories
Posted: Sun Jul 10, 2011 10:27 am
In the 36 years I have owned Babieca (1974 R75/6), I have put only 143,000 miles on her - deployments, overseas tours, and some laziness on my part. During that time I have put in seven batteries. I have only been stopped on the road for problems four times. Three of those times were battery induced stoppages. The fourth was a points chest full of water that eventually rusted through the points spring and it stopped - wiped it out, put in spare points and back on the road in 45 minutes.
The first battery failure was due to the original (&*^%*%#$%# Varta POS. It gleefully corroded terminals and leads. I was in Snyder, Texas at a stop light in 1975 when it ate thru the positive cable. Fortunately I was at the door of the local hardware store and was able to buy a brass screw-on terminal fitting. I later made/carried three short cable inserts in case it happened again - never did.
The second battery failure was a Yuasa in 1981. Yuasas were pretty good and reduced or eliminated corrosion. They lasted pretty well too; four years or more. Unfortunately I was in Yuma, Arizona in the fourth year of the battery's life. Fortunately I have a kick starter and the battery had just enough juice to allow that method of starting.
I installed a Walus battery tray soon therafter and got 5 years each out of three U1 tractor batteries. They gave good indication of impending failure and were a massive 32 A size. The last one lasted five years despite being half cooked by a bad voltage regulator.
With the advent of AGM, I became enamored of the "smaller" BMW size 28 A batteries and in January of 2010vreturned to the standard BMW battery tray and a WestCo 28 A AGM battery. Last week, 1.5 years later, 50 miles outside of Hays, Kansas in 100 degree heat, the WestCo died. A great guy on a Honda GW from Tennessee jump started me and accompanied me to Hays (a three-hour episode too long to recount here), where a 20 A AGM WalMart motorcycle battery and an initial charge at the Harley shop got me back on the road to and from Denver. Had I retained my Walus tray I could have bought a $25 U1 tractor battery at Home Depot. Oh well...
What are your experiences with batteries failing? How many of you have had AGM batts fail prematurely?
Semper pondering,
Teo
Semper pondering,
Teo
