Ok Gents, the sidestand
Posted: Mon Jul 11, 2011 8:01 pm
by lrz
100/7
I wanted a factory sidestand, so ebay was my friend a year or more ago.
Already dealt w/ converting the Reynolds to a factory, including re-tapping, etc.
I've left the sidestand in the drawer because short of moving the motor up, down or out, I can't see how to install it.
What am I missing?
Barring that, tips/hints/tricks?
Re: Ok Gents, the sidestand
Posted: Mon Jul 11, 2011 11:51 pm
by Deleted User 62
I haven't done it on a /7, but I think you should be able to remove the bracket in the way, the same bracket that the side stand and center stand springs attach to, and then it should be able to slide off. On my /5 there is a notch in the case and oil pan to facilitate removal. To remove the bracket, unhook the springs and remove the front left engine mount nut and tap the through bolt in enough to remove the bracket. Assemble in the reverse order
Posted: Tue Jul 12, 2011 7:33 am
by dougie
I was able to remove/replace mine without lifting the engine.
Posted: Tue Jul 12, 2011 7:35 am
dougie wrote:I was able to remove/replace mine without lifting the engine.
Me too. And I replaced the counter sunk head bolt with a slightly shorter one.
Posted: Tue Jul 12, 2011 10:40 am
by lrz
Same method as Tim describes?
Posted: Tue Jul 12, 2011 1:22 pm
by dougie
lrz wrote:dougie wrote:I was able to remove/replace mine without lifting the engine.
As I remember - yes.
The spring thing is on the front engine mount bolt and also serves to keep the stand in place on its pivot. Once the engine bolt is backed out it can be removed and the stand slid off the pivot.
Posted: Sat Jul 16, 2011 8:18 am
by Armaguidon13
yes, you haven't to lift engine
