New indicator for worn out fork top seals...
Posted: Wed Jul 20, 2011 6:34 pm
OK, took the /5 out for first time this year to see if there was anything I was unaware of that needed looking at. I have been financially challenged (PC terminology for broke...) this year and knew she was not safe for a rational rider without new tires.
OK, stop one, front brake - seems pretty normal. Several other stops on my trip around the block and the forks begin to feel like slinky springs. Hmm... OK, so I shut off the bike then and there. Now don't get me wrong, Duane's test for slick tubes through the gators is fine and dandy, but for extreme cases such as this...
When I looked forward at the gators, they did not look right and one push down on the bars with the brake on I knew I had no forks under the front of the bike. Hey, why are those gators looking weird??? A tap/rattle to the side of either one caused a SLOSHING SOUND!
All the fork oil had evacuated to the gators... Just about as funny is that, naturally I parked it, but as I walked by 5 minutes later, the forks were now stiff as a board again and while sure, those fork tubes felt slick as snot inside their gator-like protection, I realized that in that short period, all that same oil that had filled them had swiftly drained right back into place. I do not think the complete absence of seals would blow oil either direction any faster!
One more thing to add onto the short list. Maybe I should consider walking to Ken's???
