Final drive. How worn is this in % d'ya think?
How used is this spline?
Poll ended at Sun Jul 24, 2011 5:07 am
50%
3
20%
60%
0
No votes
70%
7
47%
80%
5
33%
Total votes: 15
I know a fellow with a final drive he'd like to sell.
He's unsure how to accurately describe the spline wear. I have given him my opinion.
Now I'm after yours. Compare to the hansen's one ready to reinstall.
Image Image
Re: Final drive. How much life left.
Was it excavated Steve?
ME 109 wrote:Was it excavated Steve?
:lol: It's grease...not mud...but sure looks like it in the pic.
Is that % worn or % life left... makes a big difference...
Rob Frankham wrote:Is that % worn or % life left... makes a big difference...
Good point Rob. Worn %. Time left would also be a welcome opinion. It all adds to the discussion.
Deleted User 72
Re: Final drive. How worn is this in % d'ya think?
Post by Deleted User 72 »
The teeth and their gaps should be equal in width. Those gaps look to be at least 6 times the width of the tooth tip. If you added half the gap width to the tooth tip they would be more or less equal. Therefore 3/4 of the tooth is worn away. 75% worn, 25% left. But I'd toss it or renew.
Native /5 wrote:The teeth and their gaps should be equal in width. Those gaps look to be at least 6 times the width of the tooth tip. If you added half the gap width to the tooth tip they would be more or less equal. Therefore 3/4 of the tooth is worn away. 75% worn, 25% left. But I'd toss it or renew.
Ya, cause 25% tooth left is not 25% life left. There will still be tooth left at the moment when the whole thing fails.
I voted 80% worn. That means that it only has 20% to go before failure is likely. However, the teeth are 50% worn. As Rob said, what do you want to know.
In any case, it is time to start planning on sending it in, or replacing it.
vanzen
Post by vanzen »
Junk.
mattcfish
Post by mattcfish »
SteveD wrote:I know a fellow with a final drive he'd like to sell.
Image Image
+1 junkola.
How'd you do that vote thing?
