It can be done...
It has been done (many times)...
But it ain't as easy as that.
If you lay out the parts (either in actuality or in your mind), you will see that you can't just bolt up stock parts from various machines to make a different engine.
The biggest problem is that, if you use the 1000cc barrels and the conrods from either the 1000cc or the 650cc engine, the engine will turn no problem. You may even get it to run after a fashion (though I doubt it) but the compression ratio will be so low that it will not produce any useable power.
There are actually two ways to approach it:-
- Reduce the length of the barrels by machining so that the compression ratio is restored or
- Bore the R65 Barrel big enough to take the bigger piston.
The first solution is favourite as (or at least so I'm told) there is precious little cylinder wall thickness left if you bore the barrel out that much.
Of course, machining the bigger barrels down is still no walk in the park because the pushrod tubes will now not meet cleanly with the machinings in the crankcase so that will need to be adjusted.
As I say, it can be done but I would question if the end result is worth it. Much easier to get a set of 800cc barrels & etc. (or a 800cc engine) and get a smoother engine without the hassle.
