1981 R100RS
kutter
1981 R100RS
Post by kutter »
One Leaves and one arrives
Shed Find - Has not left the shed in over two Years.
Had to jump start with another battery. Runs well.
Only had it a week. Notes to date.
Mufflers holey - replace
Headers are Stainless Steel - need polishing
Renewed centrestand bushes to make it easier to move around and park.
Gear lever rubber
Front forks leak - seals etc
RHS carby dripping fuel - kits needed - Hoses and Filters
All rotors master, slave cylinders and hoses need renewing/replacing
Rear Konis can be rebuilt.
Handgrips to be replaced.
Check all control cables.
Neutral light non functional.
Tyres are Metzelers nearly new tread - Past their useby date 10 years old - replace.
Engine/Transmission to be removed - minor oil leaks, neutral switch?
Remove tag and repair as necessary wiring harness
Powdercoat frame - stainless bolts
Timing hole rubber plug.
Came with some history, original tools (not Complete)
Ignition keys and fuel cap key.
Original cablelock and key. Owners handbook, parts list, first aid book.
Krauser Panniers - No keys - Difficult or impossible (and Expensive) to find.
All the engine alloy parts have a coat of white corrosion - to be removed
3/85 R80 Mono
5/81 R100RS - Shed Find
kutter
Rockhampton
Queensland
Australia
Re: 1981 R100RS
Great find, nice paint BTW.
Re: 1981 R100RS
What an excellent motorcycle.
In fact, one of the best ever made.
Not that I'm biased or anything.
+1 nice paint.
Little bit of work and it will look a treat!
Re: 1981 R100RS
Yep. A lot of detail work, but the basic package looks very good.
DanielMc
Re: 1981 R100RS
Post by DanielMc »
Great find! What's the mileage?
kutter
Re: 1981 R100RS
Post by kutter »
Has got 16,600kn on the clock,
second time around.
3/85 R80 Mono
kutter
Rockhampton
Queensland
Australia
Re: 1981 R100RS
kutter wrote:Has got 16,600kn on the clock,
second time around.
Ay arh! she be a young ship then!
Re: 1981 R100RS
Hard to tell from the picture...are the front snowflakes of the newer design? The recall for the older style is still in force.
kutter
Re: 1981 R100RS
Post by kutter »
Hi Kurt,
I knew they had trouble with the early Snowflakes.
Don't know the differences between the early and later wheels.
The following marks are on the rim.
Ges Gesch (Manufacturer?)
E BMW
Typ 215
36 31-1241 164 (Part No?)
215B x 19 CP (Size)
324932 00
3/85 R80 Mono
kutter
Rockhampton
Queensland
Australia
George Ryals
Re: 1981 R100RS
Post by George Ryals »
https://www.bmwmc.net/catalog/01.pdf
Here is a link to the service bulletin on the wheels.
