Helicoil-time, OH JOY!!
Posted: Sat Nov 19, 2011 4:01 pm
by Unclviny
I changed to an extended sump on my 1973 R75/5 and began noticing a "shiny spot" under the bike in the garage, it has turned into an actual oil leak so today I decided to re-snug the sump bolts. I found that one of the bolts (front, left) although not completely stripped will not tighten-up so $41.00 later I have the Helicoil kit in hand, I'll do it tomorrow.
Vince
Re: Helicoil-time, OH JOY!!
Posted: Sat Nov 19, 2011 8:06 pm
by Garnet
Smart guy like you, EZ PEEZEE.
Posted: Sat Nov 19, 2011 11:52 pm
by Chuey
How cool. A "thread" on Heli-Coils. I love wordplay.
Posted: Sat Nov 19, 2011 11:58 pm
Sounds like too much torque and not enough action.
Posted: Sun Nov 20, 2011 12:58 am
by mattcfish
The secret to not stripping them is to put them all in finger tight. Then apply only a slight amount of torque starting at the middle and working toward the front and back alternating sides. If you start at the front or back you will crush the gasket slightly and once the middle bolts are tightened there will be way too much torque on the ends.
Instead of Helicoiling, I've tapped the stripped ones with 7mm threads before and put in the slightly larger bolts.
Posted: Sun Nov 20, 2011 1:45 am
by Garnet
mattcfish wrote: Instead of Helicoiling, I've tapped the stripped ones with 7mm threads before and put in the slightly larger bolts.
First oversize. Does that require a break-in period?
Posted: Sun Nov 20, 2011 2:06 am
by Deleted User 62
Noop, it's already broke-in... :roll:
Posted: Sun Nov 20, 2011 2:21 am
What would be the best break-in oil?
Posted: Sun Nov 20, 2011 3:33 am
by Zombie Master
mattcfish wrote:The secret to not stripping them is to put them all in finger tight. Then apply only a slight amount of torque starting at the middle and working toward the front and back alternating sides. If you start at the front or back you will crush the gasket slightly and once the middle bolts are tightened there will be way too much torque on the ends.
Thanx Matt I'll remember that! :)
Posted: Sun Nov 20, 2011 1:43 pm
by dougie
Unclviny wrote:I changed to an extended sump on my 1973 R75/5 and began noticing a "shiny spot" under the bike in the garage, it has turned into an actual oil leak so today I decided to re-snug the sump bolts. I found that one of the bolts (front, left) although not completely stripped will not tighten-up so $41.00 later I have the Helicoil kit in hand, I'll do it tomorrow.Vince
Hey Vince, if you have a whole kit, might as well strip a couple more. :mrgreen:
